Dynamic solutions in time-independent spacetimes
In summary, the conversation discusses the understanding of dynamical solutions in the context of a static spacetime, using the example of solving Maxwell's equations on a Minkowskian static spacetime to obtain monochromatic plane wave solutions. The confusion arises from the lack of time evolution in a static spacetime, leading to questions about the introduction of time-dependency through boundary conditions and the validity of the vacuum approximation. The conversation also touches on the concept of back-reaction and the existence of exact solutions without singularities.
TrickyDicky
3,507
28
Hi, I would like to clarify this probably trivial little issue that is bugging me:
How should dynamical solutions be understood in the context of a static spacetime?
To exemplify what I mean I'll use a well known case, the source-free Maxwell eq. in their explicitly covariant form set in Minkowskian static spacetime, reduce to a EM wave eq. in the EM tensor Fab, and you can obtain solutions like the monochromatic plane wave.
My confusion arises from not seeing how such dynamical solution can happen in a static spacetime (Minkowski) that is not just stationary, which would allow time symmetry, but static so time evolution cannot even show up from crossed (dtdr..) terms.
Is the wave solution time-dependency introduced thru boundary conditions? Or am I missing anything important?
Thanks.
You can take any static spacetime and solve Maxwell's equations on it, sure. You'll get wave solutions that evolve dynamically.
But these will not be solutions of the full Einstein-Maxwell theory, because we haven't taken into account the stress-energy of the dynamic Maxwell field. Essentially, we're ignoring the effects of the EM waves on the background geometry. In my field, we'd say we're ignoring the "back-reaction" of the EM waves.
So what we have is an approximation, that holds where the geometrical effects of EM radiation are negligible.
Right, this is the starting point of my post and what I'd like to understand better.
Yes, when we do that we get the electrovacuum solutions(null for the radiation case and non-null for the rest like for instance the Reissner-Nordstrom one). But these unlike Minkowski spacetime are singular spacetimes.
Yes, we assume the field strength is small enough not to dramatically affect the geometry, this assumption is understood but it refers to the slight cheat of considering it a vacuum (here I'm paraphrasing Carroll in his exercise 6 in chapter 4 of his GR book).
My concern above is not about the solution not being strictly vacuum but with obtaining dynamical solutions in a static background, so I'm looking for a justification analogous to the one just commented for calling them vacuum but for introducing time changing fields in a static setting. Note that I'm specifically referring here to the Maxwell equations in their Minkowskian explicitly covariant form, so this is basically a formal question.
It may be true that a complete manifold for an electrovac solution is always singular (true of the cases I know); however it is certainly true that there are exact solutions with no singularities that have a charged fluid ball optionally rotating, and electrovac outside of the ball.
Interesting, can you name one?
Ok so I guess I might be either misunderstanding what a static background entails, or failing to see that the approximation in the same way it ignores the geometric effects of the EM field on the background so that it can be considered a vacuum, it ignores the time-varying nature of the EM far field so that the static Minkowskian background isn't altered, nevertheless deriving dynamic consequences like wave solutions.
I'm inclined to this last posibility, maybe this is such a usual assumption in classical field theory nobody pays much atention to it.
This is correct. I'm sure some mathematical physicist somewhere has justified and bounded the degree of validity of this, but I would not be able to point to any references for this.
I found one online: http://link.springer.com/content/pdf/10.1007/s10509-010-0521-9#page-1 (In this link, you can look inside for the first couple of pages).
Synge, 1960 has chapter on them (leading into pure electrovac solutions), but that is reference that is very hard for people to locate.
FAQ: Dynamic solutions in time-independent spacetimes
What are time-independent spacetimes?
Time-independent spacetimes are mathematical models used in physics to describe the behavior of objects in space that do not change with time. They are often used to study the behavior of systems that are in equilibrium or in a steady state.
How do dynamic solutions work in a time-independent spacetime?
In a time-independent spacetime, dynamic solutions refer to the behavior of objects that can change or evolve within the spacetime, while the spacetime itself remains unchanged. This is in contrast to static solutions, where both the object and the spacetime are unchanging.
What is the significance of studying dynamic solutions in time-independent spacetimes?
Studying dynamic solutions in time-independent spacetimes allows us to understand the behavior of systems that are in equilibrium or in a steady state, and how they may evolve over time. This has applications in various fields such as astrophysics, cosmology, and fluid dynamics.
What are some examples of systems that can be modeled using dynamic solutions in time-independent spacetimes?
Some examples include the behavior of stars in a galaxy, the movement of planets in a solar system, and the flow of fluids in a pipe. These systems can be described using mathematical equations and studied using dynamic solutions in time-independent spacetimes.
How are dynamic solutions in time-independent spacetimes different from those in time-dependent spacetimes?
In time-dependent spacetimes, both the object and the spacetime can change with time. This allows for more complex and varied solutions. In contrast, in time-independent spacetimes, the spacetime itself remains unchanged, leading to simpler and more stable solutions.
