Dynamics -- Newton's 2nd law with acceleration
In summary: For this problem, the relevant portion of the tensile force is Fx, so we can ignore the Fy component.In summary, the sleigh will get an acceleration of 1.155 m/s2.
Nanu Nana
95
A sleigh with a mass of 150 kg from rest is horizontally towed to the left
. This is done using a rope that makes an angle of 30 ° with the horizontale. The tensile force is 200 N. (Neglect friction forces.)
a. What is the horizontal component of the force?
b. What acceleration will the sleigh get ?
F: m xa[/B]
for a ) horizontal component zo
Fx = 200 N x cos (30°) = 173.2N
For b)
a= F/m => 173.2N / 150 kg = 1.155m/s^2
For b ) i thought we had to use tensile force ?? why do we use Fx instead of tensile force ?[/B]
Well, would Fx = 0 (pulling vertically) result in horizontal acceleration ?
SOrry I don't understand??
What acceleration do you expect in case Fx = 0 ?
200/150 = 1.33 m/s^2
Earth is pulling down with 150 kg x 9.81 m/s2 = 1470 N. Who wins ?
Gravity wins
Yes. So the vertical component of the tension is offset by gravity (*). Only the horizontal component can cause horizontal acceleration.
(*) The other force that acts is the normal force from the ground, that keeps the sleigh from disappearing into the earth. So unless the vertical componenet of the tension is > 1470 N, gravity wins and there is no vertical acceleration.
The acceleration of vertical component of the tension and acceleration of tension is same ?
I don't know what you mean with acceleration of tension ?
Unless you are referring to the picture, where I drew the pulling force in a vertical direction. Then the tension and the vertical component of the tension are the same.
In your exercise the pulling force is at 30 degrees.
Nanu Nana said:
For b ) I thought we had to use tensile force ?? Why do we use Fx instead of tensile force ?
Break down the 200 N tensile force into two perpendicular components (Fx and Fy).
Fx + Fy = 200 N pointing 30 degrees above horizontal.
(Note we use vector addition in this equation.)
Keeping in mind that force and acceleration are parallel, select the portion of the tensile force that is relevant to your problem, and ignore the component that is irrelevant.
Related to Dynamics -- Newton's 2nd law with acceleration
1. What is Newton's Second Law of Motion?
Newton's Second Law of Motion states that the acceleration of an object is directly proportional to the net force applied to it and inversely proportional to its mass. This means that the greater the force applied to an object, the greater its acceleration will be, and the more massive an object is, the less it will accelerate under the same force.
2. How is Newton's Second Law expressed mathematically?
The mathematical expression for Newton's Second Law is F=ma, where F represents the net force applied to an object, m represents the mass of the object, and a represents the resulting acceleration.
3. What is the difference between mass and weight in relation to Newton's Second Law?
Mass is a measure of the amount of matter in an object, while weight is a measure of the force of gravity acting on an object. Newton's Second Law deals with mass, as it is the mass of an object that affects its acceleration. Weight, on the other hand, is not directly related to acceleration, but rather to the force of gravity.
4. Can Newton's Second Law be applied to objects moving at a constant velocity?
No, Newton's Second Law only applies to objects that are accelerating. When an object is moving at a constant velocity, it means that the net force acting on it is zero, so there is no acceleration.
5. How does friction affect Newton's Second Law?
Friction is a force that opposes motion, and therefore it can have an impact on an object's acceleration. Friction acts in the opposite direction of an object's motion, so it can decrease the net force applied to an object and therefore decrease its acceleration. This is why it is important to consider friction when applying Newton's Second Law in real-world situations.
