Dynamics of ridged bodies homework help
In summary, the friction force acting at the point of contact between the barrel and the ramp is (9.81N).
biga415
hey guys, got a few different questions for you, if you can answer any of them it would be greatly appreciated!
1. a barrel of mass 2.9x10^2 kg and radius of .5m rolls down a 43 degree ramp without slipping. what is the value of the friction force acting at the point of contact between the barrel and the ramp? treat the barrel as a cylinder of uniform density.
2. the wheel of an automobile has a mass of 25 kg and a diameter of 71cm. assume that the wheel can be regarded as a uniform disk.
a) what is the angular momentum of the wheel when the automobile is traveling at 25 m/s (90km/h) on a straight road?
b) what is the torque on the wheel when the automobile is traveling at the same speed along a curve of radius 83m?
3.neutron stars spin very quickly about their axes. their high rate of spin is the result of conservation of angular momentum during the formation of the neutron star by the gradual contraction of an initially normal star.
a) suppose that the initial star is similar to the sun, with radius 8x10^8m and a rate of rotation of 2 rev/month. if this star contracts to a radius of 2x10^4m, by what factor does the moment of inertia increase? assume that the relative distribution of mass in the initial and final stars are roughly the same.
b) by what factor does the angular velocity increase?
c) what is the final angular velocity?
4.suppose that the flywheel of a gyroscope is a uniform disk of mass 250g and radius 2.5cm. the distance of the center of the flywheel from the point of support is 4cm. what is the precession frequency if the flywheel is spinning at 130 rev/s?
thanks guys!
The point of this forum is to give homework help, not to ask people to do it for you! You should first try the questions yourself, and show your working (preferably as clearly as possible), and then someone can tell you if/where you might have gone wrong.
thanks for the reply!
Id just thought id clarify that this is merely a few problems from my homework assignemnt, the rest of which i could answer. i just found it to be tedious to type up my work for these problems as i am sure it is far from correct anyways.
Related to Dynamics of ridged bodies homework help
1. What are dynamics of rigid bodies?
Dynamics of rigid bodies is a branch of mechanics that deals with the motion of solid objects without considering their deformations. It involves the study of how forces and torques acting on a rigid body affect its motion and orientation in space.
2. What are some common applications of dynamics of rigid bodies?
Dynamics of rigid bodies is used in various fields such as engineering, physics, and biomechanics. It is applied in designing machines and structures, analyzing the motion of celestial bodies, and studying the movement of human and animal bodies.
3. What are some key principles involved in dynamics of rigid bodies?
Some key principles involved in dynamics of rigid bodies include Newton's laws of motion, the principle of conservation of angular momentum, and the principle of work and energy. These principles help us understand the behavior of rigid bodies in motion.
4. How do I solve problems related to dynamics of rigid bodies?
To solve problems related to dynamics of rigid bodies, you need to have a good understanding of the principles and equations involved. It is important to draw free body diagrams and apply the relevant equations to solve for unknown quantities.
5. Are there any real-world examples that illustrate the concepts of dynamics of rigid bodies?
Yes, there are many real-world examples that illustrate the concepts of dynamics of rigid bodies. Some examples include the motion of a spinning top, the movement of a pendulum, and the rotation of a car tire. These examples demonstrate the application of principles such as angular momentum, torque, and rotational motion in everyday life.
