What is the required tension in a high wire for a 50 kg person to safely cross?
  • Thread starter magystical
  • Tags
    Dynamics
In summary, the problem involves calculating the tension in a wire that is being used for a high wire walk. The sag in the wire must not exceed 10 degrees and the mass of the person walking on it is 50 kg. To solve for the tension, one must consider the forces acting on the person, including their weight and the tension of the wire. The tension can be found by balancing the forces in the vertical direction, and taking into account the elasticity of the wire can make the problem more complicated. However, it is safe to ignore the wire's elasticity for this problem. The final answer for the tension in the wire is 1412.3384 N.
magystical
dynamics question? can you help?
Arlene is to walk across a high wire strung horizontally between two buildings 10 m apart. The sag in the rope when she is at the mid-point should not exceed 10 degrees. If her mass is 50 kg what must be the tension in the rope?
Thanks so much!
This is actually a statics problem. You need to consider the forces on Alrene: her weight and the tension of the wire. The forces make a 'Y' type shape, so that mg is pointing down, and T is pointing 10 degreesabove the horizontal to the left and the other T is pointing 10 degrees above the horizontal to the right. Balance the forces in the vertical direction to solve for T; this will be the minimum tension for a 10 degree sag; higher tensions will have less sag.
If you want to make the problem more complicated, you can consider the elasticity of the wire; the tension on each side of Arlene will be slightly higher than T, the amount of which determined by the spring constant, k, of the wire. You can find the additional elongation of these "springs" using the geometry of the situation. My initial reaction is that it's safe to ignore the elasticity of the wire, though, since even if you knew k, it wouldn't effect the answer by much.
Thanks so much!
Draw a FBD first.
The sum of forces in the vertical direction would look like this
[tex]0 = 2Tsin(10) - 490.5[/tex]
T = 1412.3384 N
FAQ: What is the required tension in a high wire for a 50 kg person to safely cross?
1. What is dynamics in science?
Dynamics in science refers to the study of the forces that cause objects to move and change their motion. It involves the analysis of the relationship between the forces acting on an object and the resulting motion.
2. How is dynamics related to Newton's laws of motion?
Newton's laws of motion are the fundamental principles that govern the behavior of objects in motion. Dynamics is closely related to these laws as it uses them to explain and predict the motion of objects under the influence of different forces.
3. What is the difference between statics and dynamics?
Statics deals with the study of objects at rest or in equilibrium, while dynamics deals with objects in motion. In other words, statics focuses on the forces that keep an object still, while dynamics focuses on the forces that cause objects to move or change their motion.
4. How is dynamics used in real life?
Dynamics is used in a wide range of applications in our daily lives, such as understanding the motion of vehicles, predicting the trajectory of projectiles, and designing structures to withstand external forces. It is also used in sports, engineering, and various other fields.
5. Can you provide an example of a dynamics problem?
A common dynamics problem is calculating the acceleration of a car on an incline, taking into account factors such as the mass of the car, the angle of the incline, and the force of gravity. This problem involves applying Newton's laws of motion to determine the resulting motion of the car.
