E.12.4 - Find plane through given point and normal to given vector
In summary, the equation for the plane through the point (3, 2, -5) and perpendicular to the x-axis is x = 3. This is because the normal vector of the plane is equal to the direction vector of the line and the family of vectors parallel to the x-axis is k<1, 0, 0>, making the equation k(x-3) = 0. Since we are given x_0 = 3, the equation becomes x = 3.
karush
MHB
3,269
$\textsf{write an equation for}$
$\textsf{ The plane through the point (3, 2, -5) and perpendicular to the x-axis}$
4ok I know this goes thru $3$ on the axis and it is \parallel to the $yz$ plane
so is it just $x=3$.
Re: E.12.4
If the plane is perpendicular to the line, the normal vector of the plane is equal to the direction vector of the line (convince yourself of this). A plane equation with normal vector \(\displaystyle \langle a,b,c\rangle\) and passing through the point $\left(x_0,y_0,z_0\right)$ is:
\(\displaystyle a\left(x-x_0\right)+b\left(y-y_0\right)+c\left(z-z_0\right)=0\)
The family of vectors parallel to the $x$-axis is:
\(\displaystyle k\langle 1,0,0 \rangle\) where $0\ne k$
And so the plane through the point $\left(x_0,y_0,z_0\right)$ and normal to the $x$-axis is then:
\(\displaystyle k\left(x-x_0\right)+0\left(y-y_0\right)+0\left(z-z_0\right)=0\)
\(\displaystyle k\left(x-x_0\right)=0\)
\(\displaystyle x=x_0\)
We are given:
\(\displaystyle x_0=3\)
And so the plane is:
\(\displaystyle x=3\quad\checkmark\)
Re: E.12.4
If the problem had said "in the yz-plane" then you would have known that x= 0, by definition of "yz-plane". The fact that it is parallel to yz-plane means that every point has the same distance from the yz-plane- and that distance is the xcoordinate.
FAQ: E.12.4 - Find plane through given point and normal to given vector
What is E.12.4?
E.12.4 is a mathematical formula used in geometry to find the equation of a plane that passes through a given point and is perpendicular to a given vector.
What is a plane in geometry?
A plane in geometry is a two-dimensional flat surface that extends infinitely in all directions.
How do you find the equation of a plane using E.12.4?
To find the equation of a plane using E.12.4, you need to have a point on the plane and a vector that is perpendicular to the plane. Plug in the values into the formula and solve for the equation of the plane.
What is a normal vector?
A normal vector is a vector that is perpendicular to a given surface or plane. It is often denoted by the symbol "n" and is used in mathematical equations to represent the direction of a surface or plane.
What is the importance of finding the equation of a plane?
Finding the equation of a plane is important in many fields of mathematics and science, such as engineering, physics, and computer graphics. It allows us to describe and analyze the relationship between points and surfaces in three-dimensional space.
