Is the Function \( f(x) = \sqrt{4 + x^2} \) Continuous Everywhere?
  • MHB
  • Thread starter mathmari
  • Tags
    Continuity
In summary, the function $f:\mathbb{R}\rightarrow \mathbb{R}$ with $f(x)=\sqrt{4+x^2}$ can be proven to be continuous on $\mathbb{R}$ using the $\epsilon$, $\delta$-definition. To show continuity, we must prove that for any $\epsilon > 0$, there exists a $\delta > 0$ such that $|f(x)-f(x_0)|<\epsilon$ for all $x$ with $|x-x_0|<\delta$. This can be achieved by choosing $\delta$ to be smaller than both 1 and $\frac{4\epsilon}{1+2|x_0|}$. In
mathmari
MHB
5,049
Hey! :eek:
I want to show that the function $f:\mathbb{R}\rightarrow \mathbb{R}$ with $f(x)=\sqrt{4+x^2}$ is continuous on $\mathbb{R}$ using the $\epsilon$, $\delta$-definition.
We have the following:
To show the continuity of $f$ we have to prove the continuity at each point $\displaystyle x_{0}\in \mathbb {R}$.
Let $x_{0}$ be an arbitrary real number.
We consider an arbitrary $\epsilon >0$.
We have to find a small enough $ \delta >0$ such that $|f(x)-f(x_{0})|<\epsilon$ for all $x$ with $|x-x_{0}|<\delta$.
First we are looking at the inequality $|f(x)-f(x_{0})|<\epsilon$ :
\begin{align*}&|f(x)-f(x_0)|<\epsilon \\ &\Rightarrow |\sqrt{4+x^2}-\sqrt{4+x_0^2}|<\epsilon\\ & \Rightarrow |\sqrt{4+x^2}-\sqrt{4+x_0^2}|\cdot \frac{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}<\epsilon \\ & \Rightarrow \frac{|(4+x^2)-(4+x_0^2)|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}<\epsilon \\ & \Rightarrow \frac{|x^2-x_0^2|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}<\epsilon \\ & \Rightarrow \frac{|x-x_0||x+x_0|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}<\epsilon\end{align*}
It must hold that $\frac{|x-x_0||x+x_0|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}<\epsilon$ for all $x$ with $|x-x_{0}|<\delta$.
So, we have to choose $\delta$ in such a way that from $|x-x_{0}|<\delta$ we get the inequality $\frac{|x-x_0||x+x_0|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}<\epsilon$.
We have that \begin{equation*}\frac{|x-x_0||x+x_0|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}\ \overset{|x-x_{0}|<\delta}{ < } \ \frac{\delta\cdot |x+x_0|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}\end{equation*}
How could we choose $\delta$ ? (Wondering)
Hi mathmari,
As we have $\sqrt{4+x^2}+\sqrt{4+x_0^2}\ge 4$, it is enough to choose $\delta$ such that $\left|x^2-x_0^2\right|<4\epsilon$; this is what you would do to prove that $x\mapsto x^2$ is continuous.
We have that $|\sqrt{4+x^2}+\sqrt{4+x_0^2}|>|\sqrt{4}+\sqrt{4}|=2+2=4$.
So, we get that $$\frac{|x-x_0||x+x_0|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}<|x-x_0|\cdot \frac{|x+x_0|}{4}\leq |x-x_0|\cdot \frac{|x|+|x_0|}{4}$$
Since $|x-x_{0}|<\delta$, we have that $$-\delta<x-x_{0}<\delta\Rightarrow x_0-\delta<x<\delta+x_0$$ Do we get from that $$|x|<|\delta+x_0|<|\delta|+|x_0|$$ ?
If this is correct, then we get the following:
\begin{align*}\frac{|x-x_0||x+x_0|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}&< |x-x_0|\cdot \frac{|x|+|x_0|}{4} \\ & < \delta\cdot \frac{\delta+|x_0|+|x_0|}{4} \\ & =\delta\cdot \frac{\delta+2|x_0|}{4} \\ & =\frac{\delta^2+2\delta|x_0|}{4}\\
& <\frac{\delta^2+2\delta|x_0|+|x_0|^2}{4} \\ & =\frac{(\delta+|x_0|)^2}{4}\end{align*}
We want that $$\frac{(\delta+|x_0|)^2}{4}<\epsilon\Rightarrow (\delta+|x_0|)^2<4\epsilon \Rightarrow \delta+|x_0|<2\sqrt{\epsilon}\Rightarrow \delta<2\sqrt{\epsilon}+|x_0|$$
Is everything correct so far?
So, do we choose $\delta:=2\sqrt{\epsilon}+|x_0|$ ?
(Wondering)
It's correct up until the last line. But if $ \delta+|x_0|<2\sqrt{\epsilon}$ then $\delta<2\sqrt{\epsilon} \mathbin{\color{red}-} |x_0|$. That unfortunately ruins the calculation, because $2\sqrt{\epsilon}-|x_0|$ might be negative, and we have to choose $\delta$ to be less than some positive quantity.
I would go back to this step:
$$\begin{aligned}\frac{|x-x_0||x+x_0|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}&< |x-x_0|\cdot \frac{|x|+|x_0|}{4} \\ & < \delta\cdot \frac{\delta+|x_0|+|x_0|}{4} \\ & =\delta\cdot \frac{\delta+2|x_0|}{4}\end{aligned}$$
The trick then is to choose $\delta$ so that both factors in that product $\delta\cdot \frac{\delta+2|x_0|}{4}$ are sufficiently small. For example, you could start by making $\delta<1$. Then $\dfrac{\delta+2|x_0|}{4} < \dfrac{1+2|x_0|}{4}$, and so $\delta\cdot \dfrac{\delta+2|x_0|}{4} < \dfrac{\delta(1+2|x_0|)}{4}$. That will be less than $\epsilon$ provided that $$\delta < \frac{4\epsilon}{1+2|x_0|}.$$
To ensure that both those conditions on $\delta$ are satisfied, you need to take $\delta < \min\bigl\{1,\frac{4\epsilon}{1+2|x_0|}\bigr\}.$
Why can we take $\delta<1$ ?
So, we don't take a specific $\delta$ we just say that it must be $\delta < \min\bigl\{1,\frac{4\epsilon}{1+2|x_0|}\bigr\}$, do we?
(Wondering)
We can make $\delta$ as small as we want, meaning we can set any arbitrary upper bound on it.
That is because what we really want, is to find a $\delta > 0$ as function $\delta=\delta(\epsilon; x_0)$ of $\epsilon >0$ and $x_0$ such that the conditions are satisfied.
And if we need to, we can make always pick a function that is smaller by a factor, or an upper bound, or whatnot. (Nerd)In our case, as Opalg explained, we can pick $\delta=\delta(\epsilon; x_0) = \min\bigl\{1,\frac{4\epsilon}{1+2|x_0|}\bigr\}$.
Or alternatively $\delta=\delta(\epsilon; x_0) = \min(1,4\epsilon)$, which is smaller.
Or alternatively we just say that we pick a $\delta=\delta(\epsilon; x_0)$ that is just smaller than a given expression. And if we want to make it explicit, we can just multiply the given expression by $\frac 12$.In case of doubt, we should check if $|f(x)-f(x_0)| < \epsilon$ does indeed hold for any $x$ with $0<|x-x_0|<\delta(\epsilon; x_0)$. (Sweating)
Ah ok!
Let ${\displaystyle \epsilon >0}$ and let $\delta < \min\bigl\{1,\frac{4\epsilon}{1+2|x_0|}\bigr\}$. If ${\displaystyle \left|x-x_{0}\right|<\delta }$ then we get the following: :
\begin{align*}|f(x)-f(x_0)|&= |\sqrt{4+x^2}-\sqrt{4+x_0^2}|\\ & = |\sqrt{4+x^2}-\sqrt{4+x_0^2}|\cdot \frac{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|} \\ & =\frac{|(4+x^2)-(4+x_0^2)|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|} \\ & = \frac{|x^2-x_0^2|}{|\sqrt{4+x^2}+\sqrt{4+x_0^2}|} \\ & < \frac{|x^2-x_0^2|}{4} \\ & = \frac{|x-x_0||x+x_0|}{4} \\ & < \frac{\delta\cdot|x+x_0|}{4} \\ & = \frac{\delta\cdot|x-x_0+x_0+x_0|}{4} \\ & = \frac{\delta\cdot|(x-x_0)+2x_0|}{4} \\ & \leq \frac{\delta\cdot (|x-x_0|+|2x_0|)}{4} \\ & < \frac{\delta\cdot (\delta+|2x_0|)}{4} \\ & \overset{ \delta\leq 1 }{ \leq } \frac{\delta\cdot (1+|2x_0|)}{4} \\ & \overset{ \delta\leq \frac{4\epsilon}{1+2|x_0|} }{ \leq } \frac{4\epsilon}{1+2|x_0|}\cdot \frac{ (1+|2x_0|)}{4}\\ & = \epsilon\end{align*}
right? (Wondering)
About Lipschitz-continuity:
Let $x,y\in [a,b]$ then we have that
\begin{align*}|f(x)-f(y)|&= |\sqrt{4+x^2}-\sqrt{4+y^2}|\\ & = |\sqrt{4+x^2}-\sqrt{4+y^2}|\cdot \frac{|\sqrt{4+x^2}+\sqrt{4+y^2}|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|} \\ & =\frac{|(4+x^2)-(4+y^2)|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|} \\ & = \frac{|x^2-y^2|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|} \\ & < \frac{|x^2-y^2|}{4} \\ & = \frac{|x+y||x-y|}{4} \\ & \leq \frac{ (|x|+|y|)}{4}\cdot |x-y| \\ & \leq \frac{ 2\max \{a,b\}}{4}\cdot |x-y| \\ & = \frac{\max \{a,b\}}{2} \cdot |x-y|\end{align*}
so $f$ locally lipschitz-continuous with constant $\frac{\max \{a,b\}}{2}$.
The function $f$ is not globally lipschitz-continuous because we cannot bound from above the term $|x|+|y|$, right? (Wondering)
mathmari said:
right?
Yep.
\begin{align*}|f(x)-f(y)| & \leq \frac{ (|x|+|y|)}{4}\cdot |x-y| \\ & \leq \frac{ 2\max \{a,b\}}{4}\cdot |x-y| \\ & = \frac{\max \{a,b\}}{2} \cdot |x-y|\end{align*}
Shouldn't that be $\frac{ 2\max \{|a|,|b|\}}{4}\cdot |x-y|$? (Wondering)
How can we be sure that is sufficient?
Shouldn't we prove that $\forall K \ge 0\ \exists x,y: \frac{|f(x)-f(y)|}{|x-y|} > K$? (Wondering)
Ah yes!
\begin{align*}\frac{|f(x)-f(y)|}{|x-y|}&= \frac{|\sqrt{4+x^2}-\sqrt{4+y^2}|}{|x-y|}\\ & = \frac{|\sqrt{4+x^2}-\sqrt{4+y^2}|\cdot \frac{|\sqrt{4+x^2}+\sqrt{4+y^2}|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|}}{|x-y|} \\ & =\frac{|(4+x^2)-(4+y^2)|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|\cdot |x-y|} \\ & = \frac{|x^2-y^2|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|\cdot |x-y|}\\ & = \frac{|x+y|\cdot |x-y|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|\cdot |x-y|}\\ & = \frac{|x+y|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|}\end{align*}
How could we continue? (Wondering)
Don't we have that $\sqrt{4+x^2}>\sqrt{x^2}=|x|$? (Wondering)
Ah! So we get the following:
\begin{align*}\frac{|f(x)-f(y)|}{|x-y|}&= \frac{|\sqrt{4+x^2}-\sqrt{4+y^2}|}{|x-y|}\\ & = \frac{|\sqrt{4+x^2}-\sqrt{4+y^2}|\cdot \frac{|\sqrt{4+x^2}+\sqrt{4+y^2}|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|}}{|x-y|} \\ & =\frac{|(4+x^2)-(4+y^2)|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|\cdot |x-y|} \\ & = \frac{|x^2-y^2|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|\cdot |x-y|}\\ & = \frac{|x+y|\cdot |x-y|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|\cdot |x-y|}\\ & = \frac{|x+y|}{|\sqrt{4+x^2}+\sqrt{4+y^2}|} \\ & < \frac{|x+y|}{|x|+|y|} \\ & <\frac{|x|+|y|}{|x|+|y|} \\ & = 1\end{align*}
Therefore we have that $|f(x)-f(y)|<|x-y|$, which means that the function is also globally lipschitz continuous, or not? (Wondering)
Indeed.
We could get a clue by looking at the graph and see that the derivative is bounded to $1$ at infinity. (Nerd)
I like Serena said:
Indeed.
Ah ok!
Having shown that the function is globally lipschitz continuous, we don't have to show seperately that it is also locally, so we don't need the part that I showed previously, do we?
Indeed. (Nod)
I like Serena said:
Indeed. (Nod)
Great! Thank you! (Smile)
FAQ: Is the Function \( f(x) = \sqrt{4 + x^2} \) Continuous Everywhere?
1. What is the ε,δ-definition of continuity?
The ε,δ-definition of continuity is a mathematical concept that defines the continuity of a function at a specific point. It states that a function f(x) is continuous at a point x=a if for any positive real number ε, there exists a positive real number δ such that if |x-a|<δ, then |f(x)-f(a)|<ε.
2. How is the ε,δ-definition of continuity different from the intuitive concept of continuity?
The ε,δ-definition of continuity is a rigorous mathematical definition that provides a precise way to determine if a function is continuous at a given point. It is based on the idea that a function is continuous if the output values do not change drastically when the input values are close together. This differs from the intuitive concept of continuity, which is a more general idea of a function being smooth and without abrupt changes.
3. Why is the ε,δ-definition of continuity important in mathematics?
The ε,δ-definition of continuity is important because it allows us to determine if a function is continuous at a specific point, which is crucial in many mathematical applications. It also helps to establish the connection between calculus and algebra by providing a way to prove the continuity of a function using algebraic methods.
4. Can the ε,δ-definition of continuity be used to determine continuity at all points of a function?
No, the ε,δ-definition of continuity can only be used to determine continuity at a specific point. To prove that a function is continuous on an interval, we need to use a combination of the ε,δ-definition and other concepts such as limits and continuity properties.
5. Is the ε,δ-definition of continuity applicable to all types of functions?
Yes, the ε,δ-definition of continuity can be applied to all types of functions, including polynomial, rational, exponential, and trigonometric functions. However, it may be more challenging to prove the continuity of some functions using this definition compared to others.
