E Field Due to Infinite Lines of Charge Where r --> 0
In summary: OP:The Attempt at a SolutionMy first thought is max E field would be at a point that would be formed by an equilateral triangle. At this point we would have a radius of 2a and the followingE = 2λ / (4 π ε0) = λ/ (2 π ε0 a) (all in +z direction)If you stay in the ##xz## plane, then it is impossible for ##r## to approach zero for either line charge.If you stay in the ##xz## plane, then it is impossible for ##r## to approach zero for either line charge.
Jake 7174
80
Two infinitely long lines of uniform charge λ lay parallel on the xy plane (0, ±a) What is max E field in the xz plane.
No values are given. Symbolic answer is expected.
equation for an infinite line of charge
E = λ / ( 2 π ε0 r)
I then think that to maximize E field I need to minimize r. So what if I observe at a distance where r approaches 0. At this point I am on the surface of one of the lines. If r = 0 the equation falls apart due to div by 0. If I take the limit as x→0 it goes undefined. If I say r=1 that's great, but 0.5 is better, and 0.005 is even better yet. I understand that I will have some field due to the other wire to figure in with my magnitude but if I am very very close to one of the lines of charge I think this will be insignificant.
Am I conceptualizing this properly?
Is there an equation for E field where r = 0?
Point well taken. I guess my original equilateral idea was the way to go.
My question still remains. What is E field on the surface of an object. Everything I have ever seen has r in the denominator. This won't help me with my homework, I just really like this stuff and want to understand it better.
I wouldn't try to answer this question based on intuition. I don't think the answer corresponds to an equilateral triangle. Also, your result for the case of an equilateral triangle is incorrect because you did not add the individual fields as vectors.
Use calculus to derive the maximum E.
As you let r approach zero for an ideal line charge, then E would approach infinity. But, the same thing happens for the ideal point charge. In real life, we do not have ideal line charges. We might have a long, straight rod of small radius R with charge uniformly spread over the surface. In that case, the maximum value of E would occur on the surface of the wire where r = R.
Use calculus to derive the maximum E.As you let r approach zero for an ideal line charge, then E would approach infinity. But, the same thing happens for the ideal point charge. In real life, we do not have ideal line charges. We might have a long, straight rod of small radius R with charge uniformly spread over the surface. In that case, the maximum value of E would occur on the surface of the wire where r = R.
What vectors did I not account for? Wouldn't everything except for the positive z components cancel due to interaction from the other wire? The closer I get to z = 0 for my reference point wouldn't I have more cancelation and less z magnitude? Conversely, the higher z I have then the larger r is and therefore smaller E. If it is not an equilateral then I really need help because I am lacking in fundamental understanding.
Here's what you wrote in your OP:
I don't see anything here that suggests that you used vector addition. Can you explain how you got your first expression for E:
E = 2λ / (4 π ε0 a) ?
(I put in a factor of "a" in the denominator that I think you meant to be there.)
TSny said:
Here's what you wrote in your OP:I don't see anything here that suggests that you used vector addition. Can you explain how you got your first expression for E:
I see what you are saying. I need to break it into components. I simply doubled the equation for infinite lines. I think my solution should then be
sin(60) * λ / (4 π ε0 a)
this is valid for one wire. for the other I should be able to multiply by 2 shouldn't I?
Yes, that will give you the net electric field at a point corresponding to an equilateral triangle.
But, you haven't shown that the equilateral triangle corresponds to the maximum electric field. (I don't think it does.)
Pick an arbitrary point on the z axis at a distance z from the origin. Find an expression for the net E at that point. Your result will depend on z. Then you can try to find the value of z that gives the maximum E.
you are right. I played with some numbers and found that the max is somewhere around 60% of what the equilateral gives. How do I prove this. The first derivative test comes to mind but that seems kind of painful given both z and the angle change. Do you have any suggestions?
Follow the suggestion in my previous post. Express E as a function of z.
ok, follow my logic for a second, I think have it.
I recognize that everything but z cancels and r = sqrt(z^2 + a^2). I still need the sine to isolate my z component. I can express sin as [ z / sqrt(z^2 + a^2) ].
If I plug these back into the expression and after a bit of simplification I will get
E = λz / [π ε0 (z^2 + a^2) ]
I took the derivative with respect to z and got something messy. I set it = 0 and found that slope is 0 at ±a. This should be my max value correct?
Good work. You have found the value(s) of z corresponding to max E. You still need to find the value of max E.
If I plug a in for z it cleans up nicely
λ / (2πε0a)
I believe that's the correct answer.
Likes Jake 7174
λ / (2πε0a)
Thank you for your help. It wasn't that bad once I got rid of a poor assumption.
FAQ: E Field Due to Infinite Lines of Charge Where r --> 0
1. What is an E field due to an infinite line of charge?
The E field due to an infinite line of charge is a vector quantity that represents the electric field strength at a point in space caused by a line of charge that extends infinitely in both directions. It is typically represented by the symbol E.
2. How is the E field calculated for an infinite line of charge?
The E field due to an infinite line of charge can be calculated using the equation E = λ / (2πε0r), where λ is the linear charge density, ε0 is the permittivity of free space, and r is the distance from the line of charge.
3. What happens to the E field as the distance from the line of charge approaches zero?
As the distance from the line of charge approaches zero, the E field becomes infinitely large. This is because the equation for the E field, E = λ / (2πε0r), has a denominator of r, which becomes smaller and smaller as r approaches zero, resulting in a larger E field.
4. Can the E field due to an infinite line of charge be negative?
Yes, the E field due to an infinite line of charge can be negative. This depends on the direction of the line of charge and the direction of the electric field at a specific point. The sign of the E field simply indicates the direction of the force that a positive test charge would experience at that point.
5. How does the E field due to an infinite line of charge compare to that of a point charge?
The E field due to an infinite line of charge is similar to that of a point charge, but there are some key differences. For example, the E field for an infinite line of charge is constant at all points along the line, whereas the E field for a point charge decreases as the distance from the point charge increases. Additionally, the E field for an infinite line of charge is always perpendicular to the line of charge, while the E field for a point charge can be in any direction.
