E-field of a moving charge at constant velocity
In summary, the "E-field of a moving charge at constant velocity" is the electric field produced by a charged particle moving at a constant speed, responsible for the movement and interaction of other charges. The strength of the E-field is directly proportional to the velocity of the charge and is always perpendicular to its direction. When the charge changes direction, the E-field also changes direction. The E-field of a moving charge is stronger and more complex than that of a stationary charge.
STosh9 said:
But I can't figure out what gamma(u) is.
That's the usual Lorentz factor of special relativity. See: Lorentz factor
Likes STosh9
Thanks. So if the charge is moving slow compared to c, then the field resembles that of a stationary charge.
Related to E-field of a moving charge at constant velocity
What is the "E-field of a moving charge at constant velocity"?
The "E-field of a moving charge at constant velocity" refers to the electric field that is produced by a charged particle as it moves at a constant velocity. This field is responsible for the movement and interaction of other charged particles within its vicinity.
How is the E-field affected by the velocity of the charge?
The strength of the E-field is directly proportional to the velocity of the charge. As the charge moves faster, the E-field becomes stronger, and as it slows down, the E-field weakens.
What is the direction of the E-field in relation to the velocity of the charge?
The direction of the E-field is always perpendicular to the velocity of the charge. This means that if the charge is moving in a straight line, the E-field will be in a circular pattern around the charge.
How does the E-field change when the charge changes direction?
When the charge changes direction, the E-field also changes direction accordingly. This is because the E-field is always perpendicular to the velocity of the charge.
How does the E-field of a moving charge compare to a stationary charge?
The E-field of a moving charge is stronger and more complex compared to that of a stationary charge. This is because the moving charge creates a changing electric field that affects the surrounding space, while a stationary charge only creates a static electric field.
