E^y + e^-y =2x or e^2y - 2xe^y + 1 = 0 equation
  • Thread starter thenewbosco
In summary, the conversation discusses how to go from the equation e^y + e^-y = 2x to e^2y - 2xe^y + 1 = 0. The participants suggest looking at the pieces of the equation and trying to manipulate it to get e^(2y) in the result. The conversation also mentions the importance of properly raising the y term.
thenewbosco
187
In this textbook i am looking at it says:
"Thus e^y + e^-y =2x or
e^2y - 2xe^y + 1 = 0"
how did they go from the first to the second part?
Mathematics news on Phys.org
Well, look at pieces of the equation and see if that gives you any clues.
For example, their second equation has an e^(2y) in it1. Can you think of anything to do to the first equation so that the result will have an e^(2y) in it?
1: I assume you meant e^(2y) and not e^2y (which is the same as (e^2)y)
You should really try to figure this out yourself. What's the difference between the two equations?
i still don't get how to go from
[tex]e^y + exp(-y)=2x[/tex]
to
[tex]e^2y - 2xe^y + 1 = 0[/tex]
help please
I'm not sure, but that y should be raised too...e^(2y) not (e^2)y
Have you tried any of our hints?
FAQ: E^y + e^-y =2x or e^2y - 2xe^y + 1 = 0 equation
What is the significance of the equation E^y + e^-y =2x or e^2y - 2xe^y + 1 = 0 in science?
The equation represents a relationship between exponential functions and is commonly used in physics, biology, and other sciences to model natural phenomena.
How do you solve the equation E^y + e^-y =2x or e^2y - 2xe^y + 1 = 0?
The first equation can be solved by taking the natural logarithm of both sides and then solving for y. The second equation can be solved using the quadratic formula.
What are the applications of the equation E^y + e^-y =2x or e^2y - 2xe^y + 1 = 0 in real life?
The equation is commonly used to model population growth, radioactive decay, and other natural phenomena in various fields such as biology, chemistry, and economics.
Can the equation E^y + e^-y =2x or e^2y - 2xe^y + 1 = 0 be solved for any value of x and y?
Yes, the equation can be solved for any real value of x and y. However, the solutions may not always be real numbers.
How does the equation E^y + e^-y =2x or e^2y - 2xe^y + 1 = 0 relate to the concept of symmetry?
The second equation exhibits symmetry about the y-axis, as it remains unchanged when the signs of x and y are switched. This can be seen by substituting -y for y in the equation, resulting in the same expression.
