Each integer n>11 can be written as the sum of two composite numbers?
Math100
Establish the following statement:
Each integer n>11 can be written as the sum of two composite numbers.
[Hint: If n is even, say n=2k, then n-6=2(k-3); for n odd, consider the integer n-9.]
None.
Proof:
Suppose n is an integer such that ## n>11 ##.
Then n is either even or odd.
Now we consider these two cases separately.
Case #1: Let n be an even integer.
Then we have ## n=2k ## for some ## k\in\mathbb{Z} ##.
Consider the integer ## n-6 ##.
Note that ## n-6=2k-6 ##
=## 2(k-3) ##.
This means ## n=2(k-3)+6 ##
=## 2m+6 ##,
where ## m=k-3 ## is an integer.
Thus, ## 2m ## and ## 6 ## are two composite numbers.
Case #2: Let n be an odd integer.
Then we have ## n=2k+1 ## for some ## k\in\mathbb{z} ##.
Consider the integer ## n-9 ##.
Note that ## n-9=2k+1-9 ##
=## 2k-8 ##
=## 2(k-4) ##.
This means ## n=2(k-4)+9 ##
=## 2n+9 ##,
where ## n=k-4 ## is an integer.
Thus, ## 2n ## and ## 9 ## are two composite numbers.
Therefore, each integer ## n>11 ## can be written as the sum of two composite numbers.
Likes usermaths
Don't use ##n## for ##k-4##, you've already used it to mean ##2k+1##!
Likes Delta2 and Math100
Yes, you're right, I shouldn't use n, I'll just use ## q ## then.
For replacement.
Other than that, is everything correct?
Yes. But "other than" is important. Never use the same variable name for two different variables.
Likes usermaths and Math100
Where did you use the condition that ##n > 11##?
Your idea works. For case #1 you may even consider ##n-4##. The ##n>11## requirement isn't really effective here. Suffices that ##n>6##.
For case #2, yes, it suffices to consider ##n-9## (because ##9## is the first odd composite on the list). One has ##2k+1-9 = 2(k-4)##. If ##n>11##, then surely ##k>5##.
Note also that this statement is optimised. You can't relax the premise to ##n\geqslant 11##, for example.
Likes usermaths and Delta2
