How Does the Sun's Position Affect the Earth-Moon Barycenter?
  • I
  • Thread starter bunburryist
In summary, the Earth-Moon barycenter is located at a distance of 4600 kilometers from the Earth's center of mass in the direction of the moon. This barycenter is also constantly moving inside the Earth due to the gravitational pull of the moon and the rotation of the Earth. The lunar component of tides is based on the differential in gravity between the near side of the Earth and the far side.
bunburryist
36
My understanding is that the Earth-Moon barycenter is about 6 kilometers from the Earth's center of mass in the direction of the moon. My question -
If the Sun is on the opposite side of the moon from the Earth, would that pull the Moon slightly away from the Earth, thus moving the Earth-Moon barycenter farther from the Earth's center of mass? Would the same thing happen if the Sun was on the opposite side of the Earth from the Moon. Would the barycenter move closer and farther from the Earth's center of mass as the Sun went (relatively) "around" our Earth-Moon system? Would it be farther when the Sun is in line with the Earth and Moon, and closer when the Sun's direction is perpendicular to the Moon-Earth line?
Astronomy news on Phys.org
Yes to all, with the addition that the barycenter is also further from the moon when the three bodies are all lined up. This effect is similar to the way the Moon influences tides on the surface of the Earth. When the Earth and Moon are aligned with the Sun, the Earth-Moon system is “stretched out” along the path of that alignment. This can happen because the entire Moon and a little bit of the Earth are located on one side of the barycenter, while the majority of the Earth’s mass is on the other side.
But these changes in distance would be tiny, and only relative to what the distances would be if the Sun did not exert a pull. The eccentricity of the Moon’s orbit is far greater. It’s never crossed my mind to calculate the actual tidal force that the Sun has on the Earth-Moon system. Sounds like fun, actually. Think I’ll give it a go, and come back with my results.
Likes Klystron
It's not though. Earth is approx 83 times more massive than the Moon, so the barycentre is at 1/83 of the Earth-Moon distance. Using the mean distance, that's approx. 4600 km from the centre of Earth, not 6.
Likes stefan r and LURCH
I can't remember where I heard that 6 kilometer bit. Thanks for straightening me out!
Some of the higher geosynchronous satellites must do a little "bobbing up and down" (relative to the earth) as the moon goes around the earth.
In addition to the barycenter being 4600 KM from the Earth's core in the current direction of the moon, it is also the case that the barycenter is the point in space that orbits the sun. This point is always moving inside the earth, both due to the rotation of the Earth and the moon's position in space relative to the earth. This means all points on the surface of the Earth (except the two places where the "line" of the Earth's orbit enters and exits the Earth's surface, passing through the barycenter), all other points on the Earth are moving at an orbital speed around the sun different from the speed they would naturally have under Kepler's 2nd law. We're held to a different speed by the rigidity of the Earth. We also feel the speed difference as a force acting on us. If you're inside the orbit of the barycenter, your body wants to orbit faster, so there is force on you toward the east (and south if your're north of the barycenter line). If you're outside the orbit line of the barycenter, your body wants to orbit slower, so there's a force on you to the west (and north or south). It's a small force for a human, but it acts on all particles around the earth, not all of them rigid --ie. water in the oceans actually starts moving in the direction that the force wants it to move. This is the solar component of tides. There's a separate Lunar component which is derived from differential of moon's gravity acting on the near vs the far side of the earth. The main point here though, is you're almost continually not going the orbital speed that physics wants you to be moving, The Earth itself is wobbling around its moving barycenter as the barycenter moves in a eliptical orbit around the sun.
Likes Drakkith
Related to How Does the Sun's Position Affect the Earth-Moon Barycenter?
1. What is the Earth-moon barycenter location?
The Earth-moon barycenter location refers to the point in space where the combined gravitational pull of the Earth and the moon is equal. It is the center of mass of the Earth-moon system.
2. How does the Earth-moon barycenter location affect tides on Earth?
The Earth-moon barycenter location plays a significant role in the formation of tides on Earth. As the moon orbits around the Earth, its gravitational pull causes a bulge in the Earth's oceans, resulting in high tides. The Earth-moon barycenter location determines the strength and timing of these tides.
3. Does the Earth-moon barycenter location change over time?
Yes, the Earth-moon barycenter location is constantly changing as the moon orbits around the Earth. It also changes over longer periods of time due to factors such as the Earth's rotation and the moon's orbit around the sun.
4. How is the Earth-moon barycenter location calculated?
The Earth-moon barycenter location is calculated using the masses and distances of the Earth and the moon. This calculation takes into account the gravitational forces between the two bodies and the effects of other celestial bodies in the solar system.
5. Why is the Earth-moon barycenter location important in space exploration?
The Earth-moon barycenter location is important in space exploration because it affects the trajectory of spacecrafts traveling to and from the moon. It is also a key factor in planning missions and determining fuel requirements for spacecrafts.
