Earth's magnetic force on a proton
The calculation of the magnetic force on a proton using the values provided yields approximately 8e-21 Newtons, but there is uncertainty regarding the chosen magnetic field strength of 50 microtesla. Participants note that the Earth's magnetic field strength can vary significantly across different locations, which may affect the accuracy of the result. The original poster is encouraged to consider this variability when selecting values for calculations. The discussion emphasizes the importance of understanding local magnetic field conditions in physics problems. Accurate results depend on precise input values, particularly for the magnetic field strength.
Jaccobtw
A proton is flying to the east near the surface of the earth at 1000m/s. What is the magnitude of the force (in N) the proton feels due to the earth's magnetic field?
F = qvBsin##\theta##
Plug in the elementary charge for q, 1000 m/s for v, 50 microtesla for B and 90 degrees for theta and I get about 8e-21 Netwons. But apparently this is wrong, anyone know why? Thank you.
Your calculation looks correct. The problem statement as given doesn't provide the strength of the B-field. The field varies quite a bit over the surface of the earth. Why did you choose 50 μT?
google!
Jaccobtw said:
google!
Click on the "varies quite a bit" in my previous post.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
