Earth's rotation having effect on sub-orbital trajectory
In summary, an object thrown with Earth's rotation will land in a different spot relative to an observer on Earth. If you attach thrusters onto that object and have it burn its fuel until it achieves orbit, the expended fuel will be less than if the Earth wasn't rotating.
ellipsis
158
24
If you throw a ball obscenely high (ignoring air resistance, etc), and the Earth is rotating, the ball will land in a different spot. Relative to an observer on the Earth, the ball has a sub-orbital trajectory across the surface. If we attach thrusters onto that ball, and have it burn at its top point until it achieves orbit, will its expended fuel be less than if the Earth wasn't rotating?
Taking this to the extreme, if the Earth was rotating very quickly, would shooting something out of the atmosphere be sufficient for it to be in orbit? Or would it follow a spiral-like trajectory across the surface? Is the reference frame of an Earth observer useless because it is non-inertial?
That depends entirely on which direction you're going to make the thrusters fire - against or with the rotation.
There's no need for extreme changes in rotation. Providing you raise the object high enough, it can get in orbit with only the tangential velocity of the rotation.
Try calculating the radius at which centripetal acceleration provided by Earth's gravity is just right to curve the path of an object moving at the speed of Earth's surface at the equator.
As you wish: 1.84 * 108 km, given a resulting circular orbit. I suspect the height for an elliptical-but-stable orbit is less, but the calculation is harder.
I get 1.84 * 106 km ([itex]GM/(R\omega)^2[/itex])... 1.84 * 108 seems like a large number... 25% further than the distance between the Earth and sun.
I had a conversation with my professor, and came to an understanding - within the reference frame of 'space', what's happening is the object being given tangential velocity equal to the Earth's rotation. This means that you're essentially throwing it at a vector relative to the Earth's surface. You can create as big a parabolic trajectory as you want (even reach escape velocity), but you can't get it into orbit from a single throw.
What is "throwing at a vector"? Relative to the Earth's surface it is thrown vertically, with no tangential velocity. Relative to an inertial frame it has a tangential velocity equal to the Earth's rotation.
By 'vector' I mean the combined vector of the vertical and tangential velocity. Throwing something upward on a spinning globe is equivalent to throwing something at an angle on a non-spinning globe.
It will not be a "parabolic" trajectory unless you happen to achieve escape velocity exactly. It could be...
A circular trajectory, if it were not for the fact that the launch angle has a vertical component, so it can't be that.
An elliptical trajectory. Which would intersect with the surface of the earth. So eventually your projectile will crash. That's the key problem with getting to orbit in a single throw.
A parabolic trajectory. If launched exactly at escape velocity.
A hyperbolic trajectory. If launched in excess of escape velocity.
A straight line (degenerate ellipse, parabola or hyperbola) if it were not for the fact that the [inertial-frame-relative] launch angle has a horizontal component, so it can't be that.
Related to Earth's rotation having effect on sub-orbital trajectory
1. How does Earth's rotation affect sub-orbital trajectory?
The rotation of the Earth affects sub-orbital trajectory in two main ways. First, the rotation of the Earth causes objects launched from its surface to move in a curved path due to the Coriolis effect. This means that the trajectory of a sub-orbital object will be slightly altered as it moves through the atmosphere. Second, the rotation of the Earth also affects the speed at which objects are launched, as the Earth's rotation adds or subtracts from the initial velocity of the object.
2. Can Earth's rotation impact the success of a sub-orbital launch?
Yes, Earth's rotation can impact the success of a sub-orbital launch. The Coriolis effect can cause the trajectory of a sub-orbital object to deviate from its intended path, which can affect its ability to reach its desired destination. In addition, the rotation of the Earth can also impact the speed and stability of the launch, which can also affect the success of the launch.
3. How does the direction of Earth's rotation influence sub-orbital trajectory?
The direction of Earth's rotation does not have a significant impact on sub-orbital trajectory. The Coriolis effect will cause the trajectory to curve in either direction, depending on whether the launch is happening in the Northern or Southern Hemisphere. However, the overall effect of Earth's rotation on the trajectory will be the same regardless of the direction of rotation.
4. Is there a specific time of day that is best for a sub-orbital launch due to Earth's rotation?
There is no specific time of day that is best for a sub-orbital launch due to Earth's rotation. The rotation of the Earth does not have a significant impact on the timing of a launch, as the Coriolis effect and the Earth's rotation will affect the trajectory in the same way regardless of the time of day.
5. How does Earth's rotation affect the amount of fuel needed for a sub-orbital launch?
Earth's rotation does not have a significant impact on the amount of fuel needed for a sub-orbital launch. While the rotation of the Earth does affect the speed and trajectory of the launch, the amount of fuel needed will primarily depend on other factors such as the weight of the launch vehicle, the desired altitude and speed, and the efficiency of the engines.
  • New Member Introductions
13K
  • Astronomy and Astrophysics
  • Classical Physics
