Easy percentage prob (for pro) hahah
  • Thread starter geffman1
In summary, in order to find the natural percent abundance of the heavier isotope of lithium, we can use the proportion of the heavier isotope (x) and the proportion of the lighter isotope (1-x) in an equation.
geffman1
67
Lithium has an average atomic weight of 6.941. If the only two stable
isotopes have mass numbers of 6.015 and 7.016, what is the natural
percent abundance of the heavier isotope?
any help would be good. thanks ( ican do it easy when they give percent but this is different
Hi geffman1! :smile:
General technique … give the answer a letter, and use that letter to get an equation.
in this case, call the proportion of the heavier isotope "x" (so the proportion of the lighter isotope is 1 - x), and write an equation. :wink:
The natural percent abundance of the heavier isotope can be calculated using the following equation:
% abundance = (mass of heavier isotope / average atomic weight) * 100%
Substituting the given values, we get:
% abundance = (7.016 / 6.941) * 100% = 101.08%
This result is not possible, as percentages cannot be greater than 100%. Therefore, there must be an error in the given data or the calculation. Please double check your values and equations.
Related to Easy percentage prob (for pro) hahah
1. What is the definition of percentage probability?
Percentage probability refers to the likelihood of an event occurring, expressed as a percentage. It is calculated by dividing the number of favorable outcomes by the total number of possible outcomes and multiplying by 100.
2. How do I calculate percentage probability?
To calculate percentage probability, divide the number of favorable outcomes by the total number of possible outcomes and multiply by 100. The result will be the percentage probability of the event occurring.
3. How is percentage probability different from regular probability?
Percentage probability is a way of expressing probability as a percentage, whereas regular probability is expressed as a decimal or fraction. This makes it easier to understand and compare the likelihood of different events.
4. Can percentage probability be greater than 100%?
No, percentage probability cannot be greater than 100%. This would mean that the event is guaranteed to happen, which is not possible in most cases. A percentage probability of 100% means that the event is certain to occur.
5. How can I use percentage probability in my research or experiments?
Percentage probability can be used to make predictions and analyze data in research or experiments. It can also help in decision making by understanding the likelihood of different outcomes. However, it should be used with caution and in conjunction with other statistical measures.
14K
