Easy Pre-Calc Question - Natural Logs
  • Thread starter sjaguar13
  • Tags
    Natural
In summary, a natural log is a mathematical function that is the inverse of the exponential function and is used to determine the power to which the base e must be raised to produce a given number. To solve equations involving natural logs, you can use logarithmic properties and basic algebraic principles. Natural logs are extensively used in calculus, particularly in integration and differentiation, and are important in finding the rate of change of a function. The domain of the natural log function is all positive real numbers and the range is all real numbers. The natural log and the exponential function are inverse functions of each other, meaning that the natural log of a number is equal to the exponent that produces that number in an exponential function.
sjaguar13
49
[tex]e^{-x^2}=(e^x)^3(\frac{1}{e^4})[/tex]
Wouldn't all the Es cancel out?
[tex]-x^2=3x-4[/tex]
Move the 3x and factor out a -x:
[tex]-x(x+3)=-4[/tex]
Now I got nothing.
try moving the -x^2 over to the right side.
OHHHH...
[tex]0=-x^2+3x-4[/tex]
Do a little factorin'
[tex](x+4)(x-1)[/tex]
[tex]x=-4 or x=1[/tex]
Both of those are the answer, right, or is there a restriction on x?
FAQ: Easy Pre-Calc Question - Natural Logs
What is a natural log?
A natural log, or ln, is a mathematical function that is the inverse of the exponential function. It is used to determine the power to which the base e (Euler's number) must be raised to produce a given number.
How do I solve equations involving natural logs?
To solve equations involving natural logs, you can use the properties of logarithms and basic algebraic principles. First, isolate the natural log on one side of the equation. Then, use the property of logarithms that states ln(a^b) = b*ln(a) to rewrite the equation. Finally, use basic algebraic techniques to solve for the variable.
Can I use natural logs in calculus?
Yes, natural logs are used extensively in calculus, particularly in integration and differentiation. The natural log function is also an important tool in finding the rate of change of a function.
What is the domain and range of the natural log function?
The domain of the natural log function is all positive real numbers, since the argument of a logarithm must be greater than zero. The range of the natural log function is all real numbers, as it can produce both positive and negative outputs.
How is the natural log related to exponential functions?
The natural log and the exponential function are inverse functions of each other. This means that the natural log of a number is equal to the exponent that produces that number in an exponential function. For example, ln(e^x) = x and e^(ln(x)) = x.
