Easy Question, but giving me trouble
  • Thread starter Dave25
In summary, the press box at a baseball park is 38 feet above the ground and a reporter in the press box looks at an angle of 15 degrees below the horizontal to see second base. Using the trigonometric function sin = opp / hyp, the distance from the press box to second base can be calculated to be approximately 142 feet. The question is asking for the horizontal distance, rather than the slope distance, and can be solved using the trigonometric function tangent = opp / adj.
Dave25
29
The press box at a baseball park is 38 feet above the ground. A reporter in the press box looks at an angle of 15 degrees below the horizontal to see second base. What is the distance form the press box to second base?
sin = opp / hyp
I am trying 38ft / sin15 and I am getting 146 ft. I know the answer is 142 ft. Or atleast that is what my book tells me the answer should be. What am I doing wrong?
Not drawing a diagram before reaching for the calculator ?
Ha! Ok, you got me there. So, I just wrote down the diagram and I still can't figure it out. So what do I need to do to solve this problem.
So you have a triangle
The angle between the horizontal and the hypotonuse is 15deg
The vertical side opposite is 38" high
Is the question asking for the horizontal distance - rather than the slope distance?
Which trig function links opposite/adjacent
Yeah, it's asking for horizontal distance and I was trying to find slope distance. Tangent is opp / adj and... my answer is 142 ft. Thanks a lot. I guess they don't give you the 2008 PF Award for nothing huh? Thanks again.
FAQ: Easy Question, but giving me trouble
What makes a question "easy" but still gives you trouble?
An easy question is one that has a simple answer or solution that is easy to understand. However, sometimes we may still struggle to find the answer due to various reasons such as lack of knowledge, confusion, or misinterpretation of the question.
How can I make sure I don't get stuck on an easy question?
One way to avoid getting stuck on an easy question is to carefully read and understand the question before attempting to answer it. It may also be helpful to break the question down into smaller parts and tackle each part individually.
Is there a specific strategy for answering "easy but tricky" questions?
Yes, there are a few strategies that can help you answer easy but tricky questions. These include eliminating obviously wrong answers, using process of elimination, and looking for keywords or hints in the question that can guide you towards the correct answer.
What should I do if I still can't answer an easy question after trying multiple times?
If you are still struggling to answer an easy question, it may be helpful to take a break and come back to it later with a fresh mind. You can also seek help from a friend, teacher, or online resources to gain a new perspective on the question.
How can I improve my skills in answering easy questions that give me trouble?
Practice is key to improving your skills in answering easy questions that give you trouble. You can also try to identify the areas where you struggle and focus on improving your knowledge and understanding in those areas. Asking questions and seeking feedback can also help you improve your skills over time.
