- #36
jim hardy
Dearly Missed
- 9,832
- 4,895
thanks sophie quite right
in my mind motor and generator are both dynamos
and I should have said 'generator action'
sloppy use of words on my part.
That's one of those bugaboos that plague me .
thanks for the correction.
Were my differential equations and my Latex better it'd be fun to tackle those equations of motion. That'd help a fellow understand damping.
I had no idea there was such an active DIY microphone community out there.
It appears the transformers are as you'd expect, made for ultra low loss.
http://www.samaraudiodesign.com/RibbonMicrophoneTransformers.html
http://www.diyrecordingequipment.com/projects/samar-ribbon-transformers/
and they call their ribbons "Motors"
http://www.diyrecordingequipment.com/projects/re-154-ribbon/
Thanks to all who've posted for the eye openers.
What an age we live in - so many projects so little time !
I have ten antique outboards and three antique pickup trucks in the queue.
i'll bow out of this one - hope to have helped with magnetics basics a little bit. It's all I can do anymore...
old jim
http://aircraftmaterials.com/data/nickel/mumetal.htmlMumetal is 80% nickel with additions of iron and molybdenum as main elements in turn this alloy offers an extremely high initial permeability. It is only moderately resistant to moisture and atmospheric corrosion, it used mainly in in transformer cores but is well known for its magnetic properties which are used for shielding electrical components from magnetic fields. "HYMU 80" has a minimum DC permeability of 80,000 at a flux density of 40 gauss when heat treated by the recommended procedure and test in accordance with ASTM 596
DIYAC RE154 Ribbon
Component Microphone Component Ribbon Microphone
The RE-154 is a ribbon motor intended for DIY ribbon microphone projects. The ribbon motor is available either fully assembled (hand made in Europe) or as a parts kit. It is manufactured and distributed by DIY Audio Components.
old jim
