MHB Edin's question via email about implicit differentiation
The discussion focuses on using implicit differentiation to find the first and second derivatives of the curve defined by the equation y^3 + y + xy^2 = 10 + 4sin(x) at the point (0, 2). For part (a), the first derivative y' is calculated to be 0 at this point. In part (b), the second derivative y'' is also determined to be 0 at (0, 2). The calculations involve differentiating both sides of the equation and substituting the values accordingly. The application of implicit differentiation is confirmed as correct.
Prove It
MHB
A curve has equation $\displaystyle \begin{align*} y^3 + y + x\,y^2 = 10 + 4\sin{(x)} \end{align*}$.
(a) Determine y' at the point (0, 2)
(b) Determine y'' at the point (0,2)
(a) Differentiate both sides of the equation with respect to x:
$\displaystyle \begin{align*} \frac{\mathrm{d}}{\mathrm{d}x} \left[ y^3 + y + x\,y^2 \right] &= \frac{\mathrm{d}}{\mathrm{d}x} \left[ 10 + 4\sin{(x)} \right] \\ 3\,y^2\,\frac{\mathrm{d}y}{\mathrm{d}x} + \frac{\mathrm{d}y}{\mathrm{d}x} + y^2 + 2\,x\,y\,\frac{\mathrm{d}y}{\mathrm{d}x} &= 4\cos{(x)} \\ \left( 3\,y^2 + 1 + 2\,x\,y \right) \frac{\mathrm{d}y}{\mathrm{d}x} &= 4\cos{(x)} - y^2 \\ \frac{\mathrm{d}y}{\mathrm{d}x} &= \frac{4\cos{(x)} - y^2}{3\,y^2 + 1 + 2\,x\,y} \end{align*}$
so at (0, 2) we have
$\displaystyle \begin{align*} \frac{\mathrm{d}y}{\mathrm{d}x} &= \frac{4\cos{(0)} - 2^2}{3 \cdot 2^2 + 1 + 2 \cdot 0 \cdot 2} \\ &= \frac{0}{13} \\ &= 0 \end{align*}$(b) Differentiate both sides of the resulting equation with respect to x again...
$\displaystyle \begin{align*} \frac{\mathrm{d}}{\mathrm{d}x} \left[ \left( 3\,y^2 + 1 + 2\,x\,y \right) \frac{\mathrm{d}y}{\mathrm{d}x} \right] &= \frac{\mathrm{d}}{\mathrm{d}x} \left[ 4\cos{(x)} - y^2 \right] \\ \left( 3\,y^2 + 1 + 2\,x\,y \right) \frac{\mathrm{d}^2y}{\mathrm{d}x^2} + \left( 6\,y\,\frac{\mathrm{d}y}{\mathrm{d}x} + 2\,y + 2\,x\,\frac{\mathrm{d}y}{\mathrm{d}x} \right) \frac{\mathrm{d}y}{\mathrm{d}x} &= -4\sin{(x)} - 2\,y\,\frac{\mathrm{d}y}{\mathrm{d}x} \end{align*}$
so at (0, 2) where $\displaystyle \begin{align*} \frac{\mathrm{d}y}{\mathrm{d}x} = 0 \end{align*}$ we have
$\displaystyle \begin{align*} \left( 3\cdot 2^2 + 1 + 2\cdot 0 \cdot 2 \right) \frac{\mathrm{d}^2y}{\mathrm{d}x^2} + \left( 6 \cdot 2 \cdot 0 + 2\cdot 2 + 2 \cdot 0 \cdot 0 \right) \cdot 0 &= -4\sin{(0)} - 2\cdot 2 \cdot 0 \\ \left( 12 + 1 + 0 \right) \frac{\mathrm{d}^2y}{\mathrm{d}x^2} + 0 &= 0 + 0 \\ 13\,\frac{\mathrm{d}^2y}{\mathrm{d}x^2} &= 0 \\ \frac{\mathrm{d}^2y}{\mathrm{d}x^2} &= 0 \end{align*}$
Mathematics news on Phys.org
Correct! Implicit differentiation was applied well.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
