Edin's question via email about volume by revolution.
In summary, we have two different methods for finding the volume of the region R when rotated about different lines. For rotating about the line $\displaystyle \begin{align*} y = 3 \end{align*}$, we use the method of washers and the definite integral is $\displaystyle \begin{align*} \pi \int_{-\frac{1}{2}}^1{ \left( 4\,x^4 - 13\,x^2 + 4\,x + 5 \right) \,\mathrm{d}x } \end{align*}$. For rotating about the line $\displaystyle \begin{align*} x = -1 \end{
Prove It
MHB
1,465
24
R is the region bounded above by $\displaystyle \begin{align*} y = 1 + x \end{align*}$ and below by $\displaystyle \begin{align*} y = 2\,x^2 \end{align*}$.
(a) If R is rotated about the line $\displaystyle \begin{align*} y = 3 \end{align*}$, construct a definite integral for the volume of the region generated.
(b) If R is rotated about the line $\displaystyle \begin{align*} x = -1 \end{align*}$ construct a definite integral for the volume of the region generated.
We should note that the two functions intersect at $\displaystyle \begin{align*} x = -\frac{1}{2} \end{align*}$ and $\displaystyle \begin{align*} x = 1 \end{align*}$.
(a) Using the method of washers, the inner radius is $\displaystyle \begin{align*} 3 - \left( x + 1 \right) = 2 - x \end{align*}$ and the outer radius is $\displaystyle \begin{align*} 3 - 2\,x^2 \end{align*}$, so the volume is
$\displaystyle \begin{align*} V &= \int_{-\frac{1}{2}}^1{ \pi \, \left( 3 - 2\,x^2 \right) ^2\,\mathrm{d}x } - \int_{-\frac{1}{2}}^1{ \pi \, \left( 2 - x \right) ^2 \,\mathrm{d}x } \\ &= \pi \int_{-\frac{1}{2}}^1{ \left[ \left( 3 - 2\,x^2 \right) ^2 - \left( 2 - x \right) ^2 \right] \,\mathrm{d}x } \\ &= \pi \int_{-\frac{1}{2}}^1{ \left[ 9 - 12\,x^2 + 4\,x^4 - \left( 4 - 4\,x + x^2 \right) \right]\,\mathrm{d}x } \\ &= \pi \int_{-\frac{1}{2}}^1{ \left( 4\,x^4 - 13\,x^2 + 4\,x + 5 \right) \,\mathrm{d}x } \end{align*}$(b) Using the method of cylindrical shells, the radius of each cylinder is $\displaystyle \begin{align*} x + 1 \end{align*}$ and the height of each cylinder is $\displaystyle \begin{align*} x + 1 - 2\,x^2 \end{align*}$. The area of each rectangular cylindrical shell is $\displaystyle \begin{align*} 2\,\pi\,r\,h = 2\,\pi\,\left( x + 1 \right) \left( x + 1 - 2\,x^2 \right) \end{align*}$, and they will all be summed up between $\displaystyle \begin{align*} x = -\frac{1}{2} \end{align*}$ and $\displaystyle \begin{align*} x = 1 \end{align*}$, thus the volume is
$\displaystyle \begin{align*} V &= \int_{-\frac{1}{2}}^1{ 2\,\pi\,\left( x + 1 \right) \left( x + 1 - 2\,x^2 \right) \,\mathrm{d}x } \\ &= 2\,\pi \int_{-\frac{1}{2}}^1{ \left( x^2 + x - 2\,x^3 + x + 1 - 2\,x^2 \right)\,\mathrm{d}x } \\ &= 2\,\pi \int_{-\frac{1}{2}}^1{ \left( 2\,x + 1 - x^2 - 2\,x^3 \right) \,\mathrm{d}x } \end{align*}$
FAQ: Edin's question via email about volume by revolution.
What is the formula for finding volume by revolution?
The formula for finding volume by revolution is V = ∫A(x)dx, where A(x) represents the cross-sectional area at a given distance x.
How is volume by revolution different from regular volume?
Volume by revolution refers to the volume of a 3D object that is obtained by rotating a 2D shape around an axis. Regular volume refers to the amount of space occupied by a 3D object.
How do you calculate the cross-sectional area for volume by revolution?
The cross-sectional area can be calculated by using the formula A(x) = πr^2, where r is the distance from the axis of revolution to the edge of the 2D shape.
What is the unit of measurement for volume by revolution?
The unit of measurement for volume by revolution will depend on the units used for the cross-sectional area and distance. For example, if the cross-sectional area is measured in square inches and the distance is measured in inches, then the volume by revolution will be in cubic inches.
Can volume by revolution be negative?
No, volume by revolution cannot be negative. It represents the amount of space enclosed by the 3D object and therefore cannot have a negative value.
9K
10K
10K
10K
11K
