EDTA Titration calculation overlook needed
In summary, the Al2(SO4)3 and NiSO4 solution was diluted with 500 mL of water. Al3+ and Ni2+ were complexed by the addition of 40 mL of EDTA. The excess EDTA was then titrated with 10.07 mL of Cu2+. The Al3+ and Ni2+ were then consumed by the F- ions that were added to displace the EDTA.
ssb
119
25.00 Ml sample of a solution of Al_2(SO4)3 and NiSO4 was diluted to 500.0 mL and the Al^3+ and Ni^2+ in a 25.00 mL aliquat were complexed by addition of 40.00 mL of 0.01175 M EDTA in a pH 4.8 buffer.
The excess EDTA was then back titrated with 10.07 mL of 0.00993 M Cu^2+. an excess of F- was then added to the solution to displace the EDTA that was bouned to the Al^3+. This liberated EDTA consumed 26.30 mL of 0.00993 M Cu^2+.
Calculate the mg/ml of Al2(SO4)3 (342.17 g/mol) and NiSO4 (154.75 g/mol) in the sample
Calculate moles EDTA = [tex]0.040 L * 0.01175 M = 0.0047 [/tex] mol EDTA
Calculate moles of Excess EDTA [tex]0.01007 L * 0.00993 M = .000099995[/tex] moles excess EDTA
Calculate Moles EDTA reacted with [tex]Al^{3+}[/tex] and [tex]Ni^{2+} [/tex] = [tex]0.0047 - .000099995 = 0.00037[/tex] mol total EDTA used
Moles [tex]Al^{3+}[/tex] comsumed = [tex]0.02630 L * 0.00993 M = 0.00026[/tex] moles [tex]AL^{3+}[/tex] consumed
moles [tex]Ni^{2+}[/tex] consumed = 0.00037 mol EDTA - 0.00026 mol Mol [tex]Al^{3+}[/tex] = 0.00011 mol [tex]Ni^{2+}[/tex]
Calculate mass [tex]Al_2(SO_4)_3[/tex] = [tex]0.00026 mol * 342.17 g/m[/tex] = 0.08896 grams = 8.896 mg
Calculate mass [tex]NiSO_4[/tex] = [tex]0.00011 mol * 154.75 [/tex]g/m = 0.01702 g = 1.702 mg
Mg/Ml [tex]Al_2(SO_4)_3[/tex] = 8.896/25.00 = 0.3558 mg/ml
Mg/Ml [tex]NiSO_4[/tex] = 1.702/25.00 = 0.0681 mg/ml
Do my calculations look correct? sig figs? If so I think I am getting the hang of this stuff
Not bad, but not perfect either.
0.00026 moles of Al3+, not Al2(SO4).
You took 25/500 of the original sample.
0.017 g is not 1.7 mg
Borek
equation balancer and stoichiometry calculator
CORRECTION step:
Convert moles [tex]Al_2(SO_4)_3[/tex] into moles [tex]Al^+[/tex]
[tex]Al_2 ----> 2Al^+ + 2e^-[/tex] therefore there is one mole of [tex] Al_2(SO_4)_3 [/tex] for every 2 moles of [tex]Al^+[/tex]
Calculate mass [tex]Al_2(SO_4)_3[/tex] = [tex](0.00026* mol *Al^+) (\frac {1 mol Al_2(SO_4)_3} {2 mol Al^+} )* (342.17 g/m)[/tex] = 0.04448 grams = 44.48 mg
Calculate mass [tex]NiSO_4[/tex] = [tex]0.00011 mol * 154.75 [/tex]g/m = 0.01702 g = 17.02 mg
If there were 44.48 mg [tex]Al_2(SO_4)_3[/tex] in 25.00 mL then there are 889.6 mg [tex]Al_2(SO_4)_3[/tex] in 500 mL
And if there were 17.02 mg [tex]NiSO_4[/tex] in 25.00 mL then there are 34.04 mg [tex]NiSO_4[/tex] in 500 mL
Mg/Ml [tex]Al_2(SO_4)_3[/tex] = 889.6 mg / 500.0 ml = 1.779 mg/ml
Mg/Ml [tex]NiSO_4[/tex] = 34.04/500.0 = 0.6808 mg/ml
What is Al+? Where did you get it from? And what for? And what is Al2? And this redox reaction... Sorry, but it looks like you are trying to solve titration questions having no idea about the most basic ideas.
17.02 in 25 doesn't mean 34.04 in 500.
Note: I am not checking everything, I am not calculating everything by myself, I am just writing about things obvious enough to be spotted at the first sight.
Too much spoonfeeding.
FAQ: EDTA Titration calculation overlook needed
What is EDTA titration and why is it used?
EDTA titration is a method used to determine the concentration of metal ions in a solution. It involves adding an EDTA (ethylene diamine tetraacetic acid) solution to a sample containing metal ions until the metal ions are completely complexed with the EDTA. This is used to determine the concentration of metal ions in a solution, which can be important for various scientific and industrial purposes.
How is EDTA titration calculated?
The calculation for EDTA titration involves determining the volume of EDTA solution used to completely complex the metal ions, and using this to calculate the concentration of the metal ions in the original solution. This is typically done using a formula where the volume and concentration of the EDTA solution are multiplied by a factor, known as the titration factor, which takes into account the stoichiometry of the reaction.
What is an "overlook" in EDTA titration calculation?
An "overlook" in EDTA titration calculation refers to a mistake or error made during the calculation process. This could be due to incorrect measurements, using the wrong formula, or other factors. Overlooks can lead to inaccurate results and should be avoided through careful measurement and double-checking of calculations.
Why is it important to double-check EDTA titration calculations?
EDTA titration calculations are important to double-check because small errors can have a significant impact on the accuracy of the results. Inaccurate calculations can lead to incorrect conclusions and potentially affect the validity of the entire experiment. Double-checking calculations can help ensure the accuracy of results and increase the reliability of the experiment.
What are some potential sources of error in EDTA titration calculations?
Sources of error in EDTA titration calculations can include inaccurate measurements of the volume or concentration of the EDTA solution, contamination of the sample, incorrect use of the titration factor, or human error in recording or interpreting data. It is important to be aware of these potential sources of error and take precautions to minimize their impact on the results.
