I Effect of attractive interactions on Gibbs free energy
Attractive interactions between gas molecules generally lead to a lower molar Gibbs free energy compared to an ideal gas, primarily due to decreased enthalpy. However, the effect on entropy is complex; while attractive forces can create a slight increase in order, the overall entropy of a non-ideal gas is typically lower than that of an ideal gas. This results in a delicate balance between enthalpy and entropy contributions to Gibbs free energy, making it difficult to predict the total effect without specific conditions. The entropy change due to these interactions is minimal, often undetectable in experiments, particularly in common gases. Overall, while attractive interactions do influence Gibbs free energy, their impact is subtle and varies with the gas type and conditions.
wnvl2
Will the presence of attractive interactions between gas molecules raise or lower the molar Gibbs energy of a gas relative to its ‘perfect’ value?
I would think that these attracting forces result in a lower energy state. A decrease in the energy state implies a decrease in the enthalpy. A reduction of the enthalpy implies a lower Gibbs-free energy.
But what will happen to the entropy?
I think that we will get less disorder as the molecules attract each other. And ther will be a little bit more order, even when there is no condensation. For the Gibbs free energy, which is equal to G=H-TS, this means that both effects have to be balanced. So we cannot say in advance what the direction is of the total effect of attractive forces is on the Gibbs-free energy.
Is that reasoning correct?
Science news on Phys.org
Entropy and enthalpy effects of molecular clusters can be said to be balanced only if exactly 50% of clusters are dissociated. Generally, such balance do not exist. For most common gases (except for water vapour), entropy contribution is much larger and molecules do not cluster in gas phase at room temperature despite of existence of attraction between them
But does that mean that when the attractive interactions in a gas increase, but it is not enough to make the gas condensate, that the effect on the entropy is zero or is there a little decrease of the entropy as the molecules are a little bit attracted to each other?
Latter is true. Entropy of non-ideal gas is (a little) lower compared to entropy of ideal gas. This would manifest in experiment as very minor decrease of isobaric thermal capacity below theoretical 0.5⋅(i+2)⋅R
Effect is really small (entropy change is below 1/200000 for xenon at ambient conditions), and i am not sure if it was ever measured. In diatomic gases, it completely swamped by thermal capacity changes due to activation of rotational degrees of freedom.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
