Effect of filters on frequency response
In summary, while experimenting with audio design on NI Multisim, the speaker created a 2nd order low pass filter with capacitors and discovered that the 2nd stage of the filter affected the frequency response of the 1st stage. This suggests that designing more complex filters in a block by block manner may encounter issues as later blocks can impact earlier ones. The speaker is seeking an explanation for this phenomenon and was advised to separate the impedances of the two stages by at least a decade or use an active filter. They were also reminded to check if the 2nd stage output is across the capacitor for a 40 db/decade response.
jordanstreet
I’m interested in audio design and was messing around with NI Multisim building some basic filters. I created a 2nd order low pass filter with capacitors and found that the 2nd stage of the filter impacts the frequency response of 1st filter as illustrated below.
This would seem to indicate that you would run into issues designing more complex filters or tone stacks in a block by block manner as components in later blocks would affect the response of earlier blocks.
I don’t know why this is and was hoping someone here could explain it to me :)
http://img689.imageshack.us/img689/7316/filterinfluence.jpg
Thanks,
Jordan Street
your second stage loads down the first
separate their impedances by a decade at least - make 2nd stage 10K and 0.1uf
or use active filter.
ps didn't you want 2nd stage output across the cap? should get your 40 db/decade then.
FAQ: Effect of filters on frequency response
1. What is a frequency response?
A frequency response is a measure of how a system responds to different frequencies of input signals. It shows the amplitude and phase of the output signal relative to the input signal.
2. How do filters affect frequency response?
Filters can attenuate or amplify certain frequencies in a signal, thus changing the overall frequency response of a system. Different types of filters, such as low-pass, high-pass, and band-pass, have different effects on the frequency response.
3. What is the difference between analog and digital frequency response?
Analog frequency response refers to the response of a system to continuous analog signals, while digital frequency response refers to the response of a system to discrete digital signals. Digital signals are represented by a series of discrete samples, which can lead to distortions in the frequency response compared to analog signals.
4. How do I measure the effect of filters on frequency response?
The effect of filters on frequency response can be measured by sending a known input signal through the system and measuring the resulting output signal. This can be done using various tools such as oscilloscopes, spectrum analyzers, and signal generators.
5. What are some common applications of filters in frequency response?
Filters are commonly used in audio systems, such as equalizers and crossovers, to adjust the frequency response for specific purposes. They are also used in telecommunications, radar systems, and image processing to remove unwanted frequencies or enhance certain frequency components in a signal.
