Effect of friction on the tension in a pulley
In summary, the tension in a pulley system with two masses (one smaller, one larger) increases when there is no friction, but decreases when there is friction.
rasen58
71
I measure the tension in a pulley system with two masses (one smaller, one larger) where I pull the small mass down and let it go so that the system accelerates in the direction of the larger mass. This is without friction.
Then, I try to consider friction. Does the tension in the string change?
How I tried to think about it was on either side of the pulley. So on the side with the smaller mass, which goes upward after letting go, if there is friction, then the friction force points downward and adds with the gravitational force. So therefore, I think that the tension force pointing upwards has to increase as well to balance the new friction force pointing downward.
But if you look on the other side, with the large mass, you see that it is going down. So the gravitational force points down and the tension force points up. The new friction force also points up, but because the gravitational force can't change, I think that the tension force would have to decrease to match the increase in friction force upwards, so that the net force stays the same.
But the tension can't increase on one side and decrease on the other, so I'm confused. Did I think about it in the wrong way?
Does the string slide over the surface of the pulley? Does the pulley have mass? Is there friction in the bearings of the pulley?
Chet
I would think the string slides over the surface of the pulley?
Massless pulley
There is friction everywhere on the pulley that there can be friction, I don't think it would matter where in order to analyze the problem
Really? Usually a pulley is meant to rotate, so the string doesn't have to slide.
If you want to analyze it quantitatively, then it does matter if the friction force is at the pulley axle (no sliding) or the string directly (sliding).
Oh right, well the pulley actually does rotate, my fault.
Then I guess the friction is at the pulley axl
Why not? If you're assuming that the tensions on the two sides have to be equal, this is true only if there is no friction in the pulley and the pulley is massless. To see this, apply the rotational form of Newton's Second Law to the pulley: $$\sum \tau = I \alpha$$
@jtbell So I was right? It actually does increase on one and decrease on the other? Thanks
FAQ: Effect of friction on the tension in a pulley
1. How does friction affect the tension in a pulley?
Friction can cause a decrease in the tension in a pulley by creating opposing forces that act against the motion of the pulley. This can result in a decrease in the efficiency of the pulley system.
2. Can friction increase the tension in a pulley?
In some cases, friction can actually increase the tension in a pulley. This can occur when the friction between the pulley and the rope or belt is strong enough to prevent slipping, resulting in a higher tension in the rope or belt.
3. How does the coefficient of friction affect the tension in a pulley?
The coefficient of friction is a measure of the amount of friction between two surfaces. A higher coefficient of friction can result in a higher amount of friction between the pulley and the rope or belt, leading to an increase in tension in the pulley system.
4. What is the relationship between friction and tension in a pulley?
The relationship between friction and tension in a pulley is inverse. As friction increases, tension decreases, and vice versa. This is because friction creates opposing forces that act against the motion of the pulley, resulting in a decrease in tension.
5. How can the effects of friction on tension in a pulley be minimized?
To minimize the effects of friction on tension in a pulley, lubricants can be used to reduce the friction between the pulley and the rope or belt. Additionally, using materials with low coefficients of friction can also help to reduce the impact of friction on the tension in a pulley.
