Effect of media on electric force
In summary, if two charges are non-spherically-symmetric and are both in medium 1, the electric force between the charges is the same regardless of the presence of another medium with different properties.
Gavroy
235
I was thinking about the following: Assuming that you have NON SPHERICALLY SYMMETRIC charges and they are both in medium 1. Does it make a difference(whereby I am referring to the total force between these two charges) if there is a second medium 2 in the local area of both? So both charges are in medium 1 and there is a medium 2 where some electrical field lines go trough? Does this have any effect on the force if there is another medium where field lines go through?
Set up a specific situation and apply Gauss' Law or Poisson's equation and see.
Is there a special reason the charges need to be non-spherically-symmetric?
So no, it does not change anything right?
You should do the math :)
Put two charges separated by distance r in medium with relative permittivity ##\epsilon_r## while there is an empty region nearby.
but if I take the surface(in Gauss law) such that there are only electric field lines, that are in medium 1, then it does not matter that there is another medium, right? So the electric field is the same. I would thank you if you could confirm this idea, somehow.
That's the idea - the force on charge 2 due to charge 1 depends on the charge enclosed by the Gaussian surface and the medium charge 2 is in. At this level, everything is decided locally. That's the advantage of the electric field model - pretty soon you will use electric force less and less and do more and more physics using fields.
(Also look at what happens when the charges are in different media.)
Your reasoning is not bad - you should be able to figure stuff out more confidently with a bit of practice - hint: most of physics is just asking useful questions.
Don't forget the "thanks" button :)
Likes 1 person
Related to Effect of media on electric force
What is electric force?
Electric force is a fundamental force of nature that describes the attraction or repulsion between charged particles. It is responsible for the behavior of electrically charged objects and is a key concept in understanding the behavior of electricity and magnetism.
How does media affect electric force?
Media, such as television and radio waves, do not directly affect electric force as they do not carry electric charge. However, media can indirectly impact electric force by influencing the behavior and actions of people, who are charged particles. For example, media can shape public opinion and policies, which can ultimately affect the use of electric force in society.
What are the potential negative effects of media on electric force?
One potential negative effect of media on electric force is the promotion of wasteful and excessive use of electricity. This can lead to environmental damage and contribute to the depletion of natural resources. Additionally, media can perpetuate misinformation about electric force and its uses, leading to misunderstandings and misuse.
How can media have a positive impact on electric force?
Media can have a positive impact on electric force by promoting awareness and education about its uses and potential benefits. This can include highlighting sustainable and efficient ways to use electricity, as well as showcasing innovative technologies that utilize electric force for the betterment of society.
What role does media play in shaping public perception of electric force?
Media plays a significant role in shaping public perception of electric force. Through news coverage, advertisements, and entertainment, media can influence how people view and understand electric force. This can impact public attitudes, behaviors, and policies related to the use of electricity and its effects on the environment and society.
