Effect of pressure on melting point.
In summary, the conversation discusses the calculation of modified melting and boiling points for a substance under different atmospheric pressures. The equation provided is T2 = 1/((1/(T1))-Math.log(Pressure/1)*R / (Hv * 1000)), with R representing 8.314 and Hv representing the heat of vaporization in kJ/mol. The conversation also mentions the use of enthalpy values and the Clausius-Clapeyron relation in this calculation. There is also a mention of the possibility of incorrect results due to the assumption of constant enthalpy.
ExcessRed
Is there a quantifiable value for a given substance that correlates to the degree by which pressure has an effect on the element or substance melting/boiling point?
Allow me to elaborate.
If the substance in question is known (silicon dioxide, for example), how could we calculate the modified melting/boiling points given n bars of atmospheric pressure? Bonus points if you can explain why some chemicals skip the liquid phase under certain pressure conditions.
Chemistry news on Phys.org
Solved the problem myself, but thought you guys might like to know the solution:
T2 = 1/((1/(T1))-Math.log(Pressure/1)*R / (Hv * 1000));
R = 8.314
Pr = Pressure you're solving for (in bars.)
Hv = Heat of vaporization for the substance in kJ/mol.
T1 = Boiling point at 1 bar of pressure.
T2 = the solution!
Edit: To clarify, Math.log() in this context refers to log base e (2.718...)
This equation may be OK for boiling point change. But is it applicable to change in the melting point with change in pressure?
Are you sure it works with enthalpy of fusion? I've tried substituting the values for that phase change, but none of them are coming up correct.
There are no assumptions about what kind phase transition takes place, however, there is an assumption that enthalpy is constant (not a function of P, T) - it is quite possible that's why you get incorrect result.
Related to Effect of pressure on melting point.
What is the effect of pressure on melting point?
The effect of pressure on melting point is that an increase in pressure can cause a substance's melting point to increase, while a decrease in pressure can cause a substance's melting point to decrease.
Why does pressure affect melting point?
Pressure affects melting point because it influences the intermolecular forces between molecules. Higher pressure can compress these forces, making it more difficult for molecules to break free and melt.
How does pressure affect the melting point of different substances?
The effect of pressure on melting point can vary depending on the type of substance. For example, for most substances, an increase in pressure will cause the melting point to increase. However, for substances that have a negative slope on their phase diagram, an increase in pressure will cause the melting point to decrease.
What happens when pressure is applied to a solid substance?
When pressure is applied to a solid substance, the molecules are pushed closer together, increasing the intermolecular forces. This makes it more difficult for the solid to melt, causing the melting point to increase.
How is the effect of pressure on melting point measured?
The effect of pressure on melting point can be measured using a pressure melting point apparatus. This equipment applies pressure to a sample of the substance while heating it, and the temperature at which the substance begins to melt is recorded as the melting point under that pressure.
