Sandi
- 1
- TL;DR Summary
- Hypothesis: heat loss increases with radius but at a less than 1:1 rate
1. My first hypothesis is that the thermal conditions of a ground source heat pump (GSHP) ground loop never reach steady state because the thermal mass of the surrounding soil is large enough that the time constant for temperature gradients moving away from the pipe before reaching boundary conditions is comparable to the time between the change of seasons
2. My second hypothesis is that a larger pipe diameter will transfer more heat to the surrounding soil, but that the increase will be less than 1:1, meaning that a doubling of the pipe diameter will not result in twice as much heat moving into the soil.
To simplify the calculation, I am assuming a single cylindrical ground-loop pipe rather than the typical pair of pipes joined at the end with a u-fitting.
Has anyone derived a formula showing the correlation between pipe radius and heat transfer per unit length assuming all other conditions remain fixed? If a mathematical correlation cannot be expressed, has anyone used thermal modeling software to derive an approximate expression for the correlation?
