Aayush Verma
- 4
New user has been reminded to please use proper sentence structure and punctuation in the future.
- Homework Statement
- I am a high school student and I tried to solve a problem on Kinetic Theory of Gases and ended up being confused at a question given below.
as far as my understanding goes, the pressure exerted by an ideal gas inside walls of a cubic container according to assumptions and postulates of kinetic theory is given by the equation given below. as a gas molecule inside the container (at a particular instant when the rocket is flying upwards) is not in contact of the vessel, it shall hit with the container's bottom wall and there should be a very large impulse imparted to the wall by collision between gas molecule and the wall (assume the collision is elastic)
and so the pressure of whole mixture should increase on all walls, and gravity will not affect the speed of the gas along vertical very much wether the gas is light or heavy because ultimately, the impulse is so large, the change in pressure will be significant and uniform enough in the container.
this is what i thought and then applied conservation of momentum to verify the factor given in option C but the expression came out something close, not exact. the correct option is B.
now I looked at the formula of pressure exerted by the gas on a wall of the container and what I found was that this formula was derived in the frame of reference of the container in which the gas is kept and also we notice this phenomena during the time where the container is already moving with the rocket so if it was initially at rest and then it started to move along with the rocket so basically the increase in pressure is not observed.
what we observed is the changed pressure which remains constant in our observation from ground. I want to know if my thinking is correct or not.
- Relevant Equations
- The equation link is not working so i posted the image
