Effect of Temperature on Chemical Equilibrium
In summary, according to the Arrhenius Equation, for any reaction, the rate constant will depend on the temperature. However, according to Le Chatelier's Principle, the equilibrium constant should not depend on the temperature. This paradox is unresolved.
Bipolarity
776
Hi guys I am a student of AP Chemistry. I am trying to understand the effect of temperature on equilibrium. I know that under the change of temperature, the equilibrium will shift to favor the endothermic process if heat is added and vice versa. But employing the Arrhenius Equation, I see a necessary concentration.
[tex]
Suppose that `⇌`(A, B);
print(`output redirected...`); # input placeholder
A ⇌ B
According to the definition of rate laws,
Rate*forward = k[A][A];
and
Rate*reverse = k;
where
k; is the rate constant
[X]; is the respective concentration of substance X.
Also, according to the Arrhenius Equation, for any reaction,
k = A*exp(-E[a]/RT);where
A; is a constant
E[a]; is the activation energy
R is the gas constant
T is the temperature at which the reaction
According to the definition of the equilibrium constant,
K[c] = k[A]/k and k[A]/k = A[1]*exp(-E[a1]/RT)/(A[2]*exp(-E[a2]/RT)) and A[1]*exp(-E[a1]/RT)/(A[2]*exp(-E[a2]/RT)) = A[1]*exp(E[a2]-E[a1])/A[2];
Therefore the K[c]; does not depend on T, which contradicts with Le Chatelier's Principle!
How can I resolve this paradox, or what is the fault with my logic?
[/tex]
Chemistry news on Phys.org
Suppose that [tex]
`⇌`(A, B);
A ⇌ B
and
> Rate*reverse = k;
where
> k;
[X]
/ E[a]\
k = A exp|- ----|
\ RT /
where
A
is a constant
E[a]
/ E[a1]\ / E[a1]\
A[1] exp|- -----| A[1] exp|- -----|
k[A] k[A] \ RT / \ RT /
K[c] = ---- and ---- = ----------------- and ----------------- =
k k / E[a2]\ / E[a2]\
A[2] exp|- -----| A[2] exp|- -----|
\ RT / \ RT /
A[1] exp(E[a2] - E[a1])
A[2]
Therefore the
K[c]
How can I resolve this paradox, or what is the fault with my logic? [/tex]
It's your maths, you are forgetting that eA/eB is eA-B not eA/B. :smile:
What?? How were you able to read that?? I can't get LaTeX to work... I'm new to this sorry. I use Maple but don't know how to translate it to LaTeX.
In any case, thank you SO MUCH FOR YOUR POST! IT FINALLY MAKES SENSE!
Regards,
BiP
LatTeX here is used just for formulas, besides, what you wrote was not in LaTeX. See our LaTeX guide.
I would like to commend you for delving into the complexities of chemical equilibrium and the effect of temperature on it. Your understanding of the basic principles is commendable, and I am happy to help you resolve the paradox you have encountered.
Firstly, it is important to note that the Arrhenius equation is used to determine the rate constant of a reaction, not the equilibrium constant. The equilibrium constant is a measure of the ratio of products to reactants at equilibrium, and it is not affected by changes in temperature. This is in line with Le Chatelier's Principle, which states that a system at equilibrium will respond to changes in external conditions in a way that minimizes the effect of those changes.
In the case of temperature changes, the equilibrium will shift to favor the endothermic or exothermic reaction to maintain a constant equilibrium constant. This means that while the rate of the forward and reverse reactions may change, the equilibrium constant will remain the same.
Your mistake lies in equating the rate constant with the equilibrium constant, which are two separate entities. The Arrhenius equation describes the relationship between the rate constant and temperature, but it does not take into account the equilibrium state of the reaction.
In summary, your understanding of the effect of temperature on equilibrium is correct. However, the Arrhenius equation is not applicable to equilibrium constants, and your logic is faulty in equating the two. I would suggest further studying the concepts of equilibrium and rate laws to gain a deeper understanding of the topic.
FAQ: Effect of Temperature on Chemical Equilibrium
1. How does temperature affect chemical equilibrium?
The effect of temperature on chemical equilibrium depends on whether the reaction is exothermic or endothermic. In an exothermic reaction, an increase in temperature will shift the equilibrium towards the reactants, while a decrease in temperature will shift it towards the products. In an endothermic reaction, the opposite is true.
2. How does Le Chatelier's Principle explain the effect of temperature on chemical equilibrium?
Le Chatelier's Principle states that when a system at equilibrium is subjected to a change, it will adjust to counteract the change and maintain equilibrium. In the case of temperature, an increase or decrease will cause a shift in the equilibrium to counteract the change and maintain a constant temperature.
3. What is the relationship between temperature and equilibrium constant?
The equilibrium constant, K, is a measure of the concentrations of products and reactants at equilibrium. It is only affected by temperature for reactions that involve gas molecules. For these reactions, an increase in temperature will increase the value of K, while a decrease in temperature will decrease the value of K.
4. Can temperature affect the rate of a chemical equilibrium reaction?
Yes, temperature can affect the rate of a chemical equilibrium reaction. An increase in temperature will generally increase the rate of a reaction, while a decrease in temperature will decrease the rate. However, the equilibrium position will remain the same as long as the temperature does not change.
5. How does temperature affect equilibrium in reversible reactions?
In reversible reactions, an increase in temperature will favor the endothermic reaction, while a decrease in temperature will favor the exothermic reaction. This will result in a shift in equilibrium towards the products or reactants, respectively. However, the equilibrium position will remain the same as long as the temperature does not change.
