Effect of Temperature on Solubility
In summary, the solubility of some solids decreases with an increase in temperature due to an exothermic reaction that produces a lot of heat in the solution. The increase in temperature does not always lead to an increase in solubility, as it also affects the thermodynamics of the system, specifically LeChatelier's principle and the change in ΔG (Gibbs free energy) which is determined by both heat and entropy changes. This means that an increase in temperature can have varying effects on the solubility of a substance, depending on the specific thermodynamic conditions.
Kaneki123
120
Solubility of some some solids decrease with increase in temperature...There is an exothermic reaction so a lot of heat is produced in the solution...My question is that why does solubility decrease?...Any increase in temperature (the heat we provide) should just excite the molecules more and the solubility should increase...
Chemistry news on Phys.org
Nope. You are ignoring half of the thermodynamics here, and it is not just a matter of solubility, but of all exothermic reactions.
What does the LeChatelier's principle predict?
What about ΔG? It has two parts, one is about heat, the other is about entropy change.
Likes Bystander
Related to Effect of Temperature on Solubility
1. How does temperature affect solubility?
The temperature of a substance can greatly affect its solubility, meaning the amount of a solute that can be dissolved in a solvent. In general, an increase in temperature leads to an increase in solubility, while a decrease in temperature leads to a decrease in solubility.
2. Why does temperature affect solubility?
Temperature affects solubility because it changes the energy of the molecules in a substance. When a solvent is heated, its molecules gain energy and move faster, creating more space between them. This allows more solute molecules to fit in between the solvent molecules, increasing solubility.
3. Is there a specific temperature at which solubility is highest?
The specific temperature at which solubility is highest varies depending on the solute and solvent involved. In some cases, solubility may continue to increase with temperature, while in others it may reach a maximum and then decrease.
4. How does temperature affect the rate of dissolution?
Temperature also affects the rate of dissolution, which is the speed at which a solute dissolves in a solvent. Higher temperatures typically lead to faster dissolution because the increased energy and movement of molecules allows them to interact and mix more quickly.
5. Can temperature affect the solubility of all substances?
No, temperature does not always affect the solubility of all substances. Some substances, such as gases, may exhibit the opposite trend where solubility decreases with increasing temperature. Additionally, changes in temperature may not have a significant effect on the solubility of highly soluble substances.
  • Chemistry
  • Chemistry
