I Effect of vent ratio on the drag coefficient of round parachutes
The discussion focuses on researching the effect of vent ratio on the drag coefficient of round parachutes for a school project. The proposed methodology includes building small model parachutes and potentially a wind tunnel, although concerns are raised about the reliability of wind tunnel results due to the adjustment of airstream velocity. Participants suggest measuring terminal velocity as a more effective method, using simple video techniques to gather data. Resources and literature on parachute drag characteristics are shared to aid in the research. The importance of experimental results for calibrating simulations is emphasized, highlighting the need for both experimental and simulated data for comprehensive analysis.
prithika
TL;DR Summary
CFDs or pre-written codes that would help measure the effect of vent ratio on drag coefficient of parachutes.
For my 12th grade school project, I'm planning to research on the effect of vent ratio on the drag coefficient of round parachutes. My idea was to make small model parachutes and drop them from a height, and derive the drag coefficient after certain assumptions. But I also thought it'd be interesting to build a wind tunnel and compare the results from both experiments. However, I'm not sure how to collect drag values from a home made wind tunnel. I'd also like to use a virtual wind tunnel or CFDs to obtain more accurate results and compare my experimental data. Are there any easy CFDs using which I can model round parachutes or any pre existing code that could achieve the same purpose? I'm planning to focus on the effect of the round parachute while descending, not during inflation as it would complicate the process.
Welcome, @prithika ! :smile:
Are you familiar with terminal velocity?
https://en.wikipedia.org/wiki/Terminal_velocity
A wind tunnel should no give you the results that you expect, because the airstream velocity naturally adjusts to the coefficient of drag (Cd) for each chute-vent configuration.
Oh, so the drag coefficient stays constant in a wind tunnel while the terminal velocity is the one that differs? Is there any other method I can use to find out the effect on the drag coefficient without wind tunnels?
Yes, that is the way it works.
I don’t know other ways than experimenting and measuring terminal velocity for each case.
Let’s wait for members with experience in simulation.
You need only build one parachute with a too small vent hole. Measure the terminal velocity, enlarge the hole, measure again, repeat. Terminal velocity is easy to measure with a cell phone video camera, and software that allows you count the number of frames as it passes two marks a known distance apart. The marks can be as simple as the top and bottom of a window in the building where you drop it off an upper floor.
Note that you need the experimental results to calibrate and verify the simulation. And if you have the experimental results, do you still need the simulation?
Some good information on parachutes and vent areas: https://web.wpi.edu/Pubs/E-project/...ighenti_Duffen_Head_Vented_Parachutes_MQP.pdf. The book Fluid-Dynamic Drag, by Sighard F. Hoerner has a few pages on parachutes. Good search terms to find more good stuff are drag characteristics of parachutes.
Thank you so much! I will look into these resources. I think I require the simulation to mainly compare both the experimental values and the expected values, so that I can write a reasonable analysis and evaluation. Is there any simulation that can achieve this purpose?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
