Effect of visible light on conductivity
In summary, metals are not better conductors in the presence of visible light because they have partially filled conduction bands with a high number of electrons. However, photoconductivity is observed mostly in semiconductors, which have an empty conduction band and almost full valence band. In semiconductors, the number of electrons in the conduction band is small and increases when light is shined on them.
EngPhy
Are metals better conductors in the presence of visible light? Considering photons in visible spectrum are not energetic enough to induce emission from a metal surface but they do cause the ejection of 'conduction electrons' which are bound to the metal by a few electron volts.
No. Metal are substances which have partially filled conduction bands with electrons and the number of electrons is very high, one or two per atom.
Photoconductivity is observed mostly in semiconductors. Semiconductors have empty conduction band and almost full valence band just around 1 eV below.
The electrons in the conduction band are coming from either doping or are thermally excited and their number is rather small, one per millions of atoms.
When you shine light on a semiconductor you excite electrons from the valence to conduction band and the conductivity increases.
Good answer, thank you
Related to Effect of visible light on conductivity
What is the effect of visible light on conductivity?
The effect of visible light on conductivity can vary depending on the material being studied. In some cases, visible light can increase conductivity by exciting electrons and promoting their movement. In other cases, visible light can decrease conductivity by creating electron-hole pairs that inhibit the flow of current.
How does the wavelength of visible light affect conductivity?
The wavelength of visible light can have a significant impact on conductivity. In general, shorter wavelengths (such as blue or violet light) have a higher energy and can promote conductivity more effectively than longer wavelengths (such as red or green light).
Can visible light be used to control conductivity?
Yes, visible light can be used to control conductivity in certain materials. This is known as photoconductivity and is often utilized in devices such as solar cells. By adjusting the intensity and wavelength of visible light, conductivity can be controlled and manipulated.
What materials are most affected by visible light in terms of conductivity?
Materials that have a high number of free electrons are typically the most affected by visible light in terms of conductivity. This includes metals and some semiconductors. Insulators, on the other hand, are not as affected by visible light and have low conductivity even when exposed to light.
Are there any practical applications of the effect of visible light on conductivity?
Yes, there are many practical applications of this phenomenon. As mentioned before, photoconductivity is used in solar cells to convert light energy into electrical energy. It is also utilized in devices such as photodetectors, optical switches, and even in optogenetics - a technique used to control cells with light.
