Effect on electrostatic charge from accelerating electrons
In summary: There is no cycle. You have a capacitor that discharges over time, without external power supply the system stops quickly as all electrodes reach the same potential.
msat
I'm trying to understand (well, maybe in an oversimplified way) what permanent changes, if any, would be experienced by a positive electrostatically charged plate used to accelerate a free electron in a vacuum, but where the electron would not strike the plate.
I assume there would be some sort of temporary effects on the plate due the the field interactions between the two, but then some distance after the electron passes by, the plate charge would revert to its initial state - unaffected. But how could that be, if energy must be conserved, how would it add momentum to the electron if the plate charge is able to revert back to its initial state? So therefore the charge on the plate must be permanently changed, but by what mechanism?
Likes BvU
You have to get electrons to the source which has to be at a higher potential energy - this needs power from elsewhere. There are no changes to the positive plate.
mfb,
what do you mean by "have to get electrons to the source"? Are you referring to an electron emitting cathode, or you mean having to initially put a charge on the plate?
The cathode which emits the electrons. If you don't "replenish" them (have a current flow against a potential difference), you will stop accelerating electrons quickly.
The specifics of the electron source aren't particularly relevant to the question, imo, though I think it's safe to say you are correct.
Embarrassingly, it just dawned on me that the change I was seeking is simple Newtonian physics; the force imparted on the electron which altered its momentum would result in an equal and opposite force on the plate.
But leaving it at that puts a bad taste in my mouth. If we do start considering the electron source, specifically a field emission gun, and besides that and the charged plate, we also add an electron trap and put a conductor between the trap and gun, you'll have a continuous flow of current (assuming the trap catches 100% of the electrons, and there's no spontaneous emissions in the rest of the circuit). That can't be, but why?
msat said:
Conservation of energy is useful only if you include all components of your system, or account for external sources/drains of energy.
Without a power supply, the trap and the gun will be at the same potential quickly, at that point flow stops.
There would be a potential between the plate and the gun, which would cause it to emit electrons and it turn be at a positive charge (not for long, of course)... In theory.
That is the point. You have some energy stored in the system as it acts like a capacitor. You can convert that energy to kinetic energy of electrons or heat.
What I mean was that the field generated by the charge imbalance would induce a current down the conductor so that as long as the other end was able to collect electrons, and the cycle would continue as the gun continued to emit electrons.
Related to Effect on electrostatic charge from accelerating electrons
1. How does the acceleration of electrons affect electrostatic charge?
The acceleration of electrons can increase or decrease the electrostatic charge depending on the direction of acceleration. If the electrons are accelerated in the same direction as the electric field, the charge will increase. If they are accelerated in the opposite direction, the charge will decrease. This is known as the directional effect of electron acceleration.
2. What is the relationship between electron acceleration and electrostatic charge?
Electron acceleration and electrostatic charge have an inverse relationship. This means that as the acceleration of electrons increases, the electrostatic charge decreases, and vice versa. This relationship is described by Coulomb's Law, which states that the electrostatic force between two charged particles is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
3. Can the acceleration of electrons affect the charge of an object?
Yes, the acceleration of electrons can affect the charge of an object. If the object is conductive, the acceleration of electrons can cause the charges to redistribute, resulting in an overall change in the object's charge. This is known as induced charging. On the other hand, if the object is non-conductive, the acceleration of electrons may not have a significant effect on its overall charge.
4. How does the velocity of electrons impact the electrostatic charge?
The velocity of electrons has a significant impact on the electrostatic charge. As the velocity increases, the charge also increases. This is because the kinetic energy of the electrons is directly related to their velocity, and this energy can be converted into electrostatic potential energy. Therefore, a higher velocity means a higher charge.
5. Is there a limit to how much the electrostatic charge can change from accelerating electrons?
There is no limit to how much the electrostatic charge can change from accelerating electrons. The change in charge will depend on various factors such as the direction and magnitude of acceleration, the initial charge of the electrons, and the properties of the surrounding environment. However, it is essential to note that the total charge of a closed system will always remain constant, according to the law of conservation of charge.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
