Effect on electrostatic force due to dielectric medium.
In summary: In all these cases, the electric field is altered by the presence of the dielectric material. The field of a point charge is not a function of the medium. It is a function of the inverse square of the distance from the charge.In summary, the force between two charged particles at a distance r is F. When the particles are in a dielectric medium, the force becomes F/K. The force is not affected by the presence of a dielectric material in the other cases.
Deva
Hi! I have a high school physics question. I know the concept of induction, and I also know what happens when a dielectric slab is placed between 2 plates of a capacitor.
2 charged particles are kept at a distance r. The mutual force of attraction/repulsion is F.
What happens to the force when -
1) both particles are now kept in dielectric medium (K)
2) only one charge is kept in dielectric medium (k) other is in vacuum
3) when a dielectric slab (K) of thickness r/2 is kept between the 2 particles
4) when a random shaped dielectric solid body is placed between the 2 particles.
Also, I found this question is test:
3 concentric spherical shells are placed in vacuum. The region between the inner 2 shells is filled with dielectric material (K). What is the potential on the surface of middle shell?
The answer is independent of K. There is a possibility that it is incorrect. Can someone please explain?
Thank you!
Well this is disappointing
Should i repost this?
Have you studied Gauss' law? What is the field inside any charged conducting shell?
The dielectric will only have an effect if there is an electric field. But Gauss' law shows that there is no electric field inside these concentric conducting spherical shells.
[Note: in order to get a response you should follow the posting rules: You have to state the problem, the applicable principles/equations, and you have to show us what you have done to solve the problem].
AM
AM
Yes I know Gauss' Law.
The answer to your question would be zero.
Your post answers my last question.
But the first four are the ones that really stumped me.
Applicable Principles: Induction, Capacitance, Gauss Law.
The questions I asked are theoretical. I'm not sure how to prove that I am not asking homework (if that's what you are worried about). I just thought of all possible cases.
Here are the answers according to me:
1) F/K on both
2) F on the particle outside dielectric medium. F/K on the other one.
3) F on both
4) F on both
The logic I have used is that the net force changes only when the particle in inside the medium. If the dielectric medium is inbetween the particles, it will act as a capacitor (inducing equal-opposite charges on two surfaces, and a capacitor doesn't have electric field outside it.
1) F/K on both
I assume that K the dielectric constant of the medium.
For a charged particle placed in a dielectric medium, apply Gauss' law using a spherical Gaussian surface that encloses the charge and the medium. Is the enclosed charge any different due to the presence of the dielectric medium? So how does the field outside the dielectric medium compare to the field at the same distance from the charge without the dielectric medium?
3) F on both
4) F on both
Just apply Gauss' law. With the dielectric medium between the charges, take a gaussian surface (sphere) around each charge that just touches but does not include the dielectric medium. That will give you the field on either side of the dielectric medium. Can you relate those forces on the medium to the forces between the charges?
AM
1. F'=F/K
2, 3, and 4 are complicated problems, because the dielectric gets polarized.
2 and 3 can be solved with 'images'.
Didn't read forum guidelines regarding homework questions?
Dielectric mediums get polarized by electric fields and create counter-fields. Thus the forces between the particles should decrease (since the electric fields decrease by a factor of k, F'=F/k) whenever a dielectric encompasses both.
If a dielectric is placed between them without touching any particles, the electric field only changes (by a factor of 1/k) between them, and so the force remains the same.
If the dielectric encompasses one of them but leaves the other in vacuum, then the force will only change on one of the particles.
per gauss law, none of the dielectrics will produce an electric flux, so they are not very complex.
I am not sure how that can happen. Newton's third law still applies. The force on each charge has to be equal and opposite to the force on the other.
Gauss' law always gives the correct answer. So the field of charge A (surrounded in dielectric) at the surface of B (in vacuum) is the same as if the dielectric was not present (since the net charge on the dielectric is 0). So the force of A + dielectric on B is the same as the force of just A on B with no dielectric. So the force of B on A + dielectric must also be the same.
AM
You're probably right, but assuming both particles have equal charge, shouldn't the dielectric repel the outside particle as well? So in sum the repelling force on it is larger than on the particle inside the dielectric? This will be without Newton's 3rd law being broken, as both the particles act on each other with the same resultant forces, but the presence of the dielectric changes things.
/// Note: I'm only in my 1st year of uni, so don't take what I say for good salt
AM
How do i know that the dielectric hasn't disturbed the uniform distribution of flux in the gaussial sphere?
Your method can only hold true if it can be proven that the electric field will be uniform in all dS areas of the gaussian sphere.
That sounds reasonable only if it can be proven that electric field will be equal at all the elemental dS areas of a guassian surface.
If there is an asymmetry you would have to use Coulomb's law. The effect of the dielectric will be to superimpose an electric dipole field on the field of the charge.
The field of the charge will be uniform (Coulomb's law). But but the induced electric field of the dielectric would have to be superimposed to find the total field.
AM
Related to Effect on electrostatic force due to dielectric medium.
What is the definition of electrostatic force?
Electrostatic force is the force between two charged particles or objects that are not in motion. It is also known as Coulomb's law and is described by the equation F = (k * q1 * q2)/r^2, where k is the Coulomb's constant, q1 and q2 are the charges of the two particles, and r is the distance between them.
How does the presence of a dielectric medium affect electrostatic force?
A dielectric medium is a material that can be polarized by an electric field. When a dielectric medium is placed between two charged particles, it reduces the strength of the electric field between them, thus reducing the electrostatic force. This is because the polarized molecules in the dielectric medium create an opposing electric field that cancels out a portion of the original electric field.
What is the relationship between the dielectric constant and electrostatic force?
The dielectric constant (also known as relative permittivity) is a measure of how easily a material can be polarized by an electric field. It is directly related to the strength of the electric field, and therefore, the electrostatic force. A higher dielectric constant means a stronger opposing electric field, resulting in a weaker electrostatic force.
How does the distance between the charged particles affect the electrostatic force in a dielectric medium?
The distance between the charged particles is a critical factor in determining the strength of the electrostatic force in a dielectric medium. As the distance between the particles increases, the strength of the electric field decreases, resulting in a weaker electrostatic force. This is because the polarized molecules in the dielectric medium have less influence on the electric field at a greater distance.
What are some examples of dielectric materials and their effects on electrostatic force?
Some common examples of dielectric materials include air, glass, paper, and rubber. These materials have different dielectric constants, which affect the strength of the electric field and, consequently, the electrostatic force. For example, air has a dielectric constant of approximately 1, which means it has little effect on the electric field and the electrostatic force. On the other hand, materials with higher dielectric constants, such as glass, can significantly reduce the electrostatic force between charged particles.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
