Effect on equilibrium, addition of inert gas
In summary, the equilibrium pressure of a gas mixture is unaffected by the addition of inert gases. moles of each gas occupy the entire volume, and the partial pressures of the various gases add up to the total pressure.
Titan97
If inert gases are added at constant volume to an equilibrium mixture, the total pressure increases. But the mole fraction of the gaseous reactants or products decrease.
Partial pressure ##p=x\cdot P## where P is total pressure and ##x## is mole fraction.
How can you say that ##p## remains constant?
(I read that the equilibrium is not affected since partial pressure of the participants of equilibrium remains constant)
Chemistry news on Phys.org
Assume initial pressure of a gas to be p0. Assume 1 mole of the gas to make calculations easier. Assume volume V. Assume you have added n moles of an inert gas. What is the new total pressure? What is the mole fraction of the original gas? What is its partial pressure? Don't guess - calculate!
Likes Titan97
The mole fractions decrease by the same factor that the total pressure increases, so that the partial pressures remain the same. True or false: each gas in an ideal gas mixture exhibits PVT behavior as if the other gases are not present.
Chet
Likes Titan97
Initial mole fraction = ##\frac{1}{N}##
Initial total pressure = ##P_0##
##P_0=\frac{NRT}{V}##
##p=x.P_0=RT/V##
Let n moles of argon be added.
New mole fraction = ##\frac{1}{n+N}##
New total pressure = ##\frac{(n+N)RT}{V}##
##p'=\frac{RT}{V}##
Hence there is no change in partial pressure.
@Chestermiller Let the volume occupied by one gas be ##v##. Won't ##v## change if more gases are added? Since adding more gases means lesser volume that can be occupied.
Titan97 said:
How can you say that pp remains constant?
I assume you have just answered your own question :wink:
Likes Titan97
The molecules of each gas occupy the entire volume. The partial pressures of the various gases add up to the total pressure.
Likes Titan97
What if noble gases are added under constant pressure?
Let the equation be A(g)↔B(g)+C(g) (let ↔ be reversibility sign)
In this case, mole fraction decreases while total pressure remains constant. Volume is also constant.
Let moles of A be ##n_1##,
moles of B=##n_2##
and moles of C=##n_3##.
Let moles of argon be ##a## and total number of moles before addition of argon be ##n##.
Initially, ##K=\frac{n_2.n_3}{n_1(n)}P##
After addition of argon, ##K'=\frac{n_2.n_3}{n(n+a)}P##
(Pressure remains constant).
Hence K decreases which means products are favoured.
Is this correct?
If you add argon, pressure doesn't stay constant.
Likes Titan97
The vessel is maintained at constant pressure.
Then you are just diluting reacting gases, lowering their partial pressures - and that's a completely different case than the one you started with (you have mentioned constant volume in the very first post).
Likes Titan97
Yes. I was just thinking about a new situation. But in post 8, I found that K changed. But K can only change if temperature changes.
No, you found that Q (reaction quotient) has changed, not K. After you change volume, equilibrium will shift till Q=K.
Likes Titan97
That solves all my doubts on Le Chatelier's principles.
Related to Effect on equilibrium, addition of inert gas
1. What is the effect of adding an inert gas on equilibrium?
Adding an inert gas to a reaction at equilibrium does not alter the equilibrium constant or the concentrations of the reactants and products. However, it does increase the total pressure of the system, which can potentially shift the equilibrium in accordance with Le Chatelier's principle.
2. How does the addition of an inert gas affect the rate of a reaction?
The addition of an inert gas does not affect the rate of a reaction. Inert gases do not participate in the reaction and do not have any effect on the reaction mechanism. Therefore, the rate of the reaction remains unchanged.
3. Can the addition of an inert gas change the temperature of a reaction?
No, the addition of an inert gas does not change the temperature of a reaction. Inert gases do not have any heat capacity and do not participate in any exothermic or endothermic reactions. Therefore, they do not affect the temperature of the system.
4. Is it necessary to consider the addition of an inert gas when calculating equilibrium constant?
No, the addition of an inert gas does not affect the equilibrium constant. The only factor that affects the equilibrium constant is the temperature of the reaction. Therefore, it is not necessary to consider the addition of an inert gas when calculating equilibrium constant.
5. Can the addition of an inert gas change the concentration of reactants and products in a reaction?
No, the addition of an inert gas does not change the concentration of reactants and products in a reaction at equilibrium. Inert gases do not participate in the reaction and do not affect the equilibrium constant. Therefore, the concentrations of the reactants and products remain unchanged.
  • Materials and Chemical Engineering
