Effective field theory in Srednicki's book
In summary, the Wilsonian effective action in QFT is derived by integrating out high momentum modes above the cutoff Λ and using the renormalization group equations. The ansatz for the new coefficients is determined by the symmetries of the theory and the requirement that the effective action must reproduce the same physical predictions as the original action.
brushguy
Hi!
I'm currently learning for my QFT exam with the book from srednicki (here as pdf: http://web.physics.ucsb.edu/~mark/ms-qft-DRAFT.pdf) and I am trying to understand the chapter "Effective field theory" (p. 185 in the pdf above)
He first introduces an ultraviolet cutoff Λ and then computes the path integral over all fields with momentum above Λ.
Then he defines the "Wilsonian effective action" and writes down the corresponding lagrangian
( (29.11) on p. 186 ).
-) How can one derive eq (29.11) (the lagrangian density of the Wilsonian effective action) ?
-) Why can one compute the new coefficients m2(Λ) \alpha, λ(Λ), ... the way it is shown in eq (29.13) - (29.23) ?
I am not confused about how exactly the computation works, but with how he comes up with the ansatz itself. For example, why the new mass m(Λ) can be computed with eq (29.20)
Thanks in advance!
Hi there,
Thank you for your question about the Wilsonian effective action in QFT. The derivation of equation (29.11) can be found in many textbooks on QFT, such as Peskin and Schroeder's "An Introduction to Quantum Field Theory" or Weinberg's "The Quantum Theory of Fields". Essentially, the Wilsonian effective action is derived by integrating out the high momentum modes of the fields, which are above the cutoff Λ. This is done by performing a series of momentum shell integrals, and then using the renormalization group equations to obtain the effective action at the scale Λ.
As for the ansatz for the new coefficients m2(Λ), α, λ(Λ), etc., this is a result of the renormalization group equations and the requirement that the effective action must reproduce the same physical predictions as the original action. The specific form of the ansatz is determined by the symmetries present in the theory. For example, in a theory with a scalar field, the new mass term m(Λ) is determined by the renormalization group equation for the mass parameter and the requirement that the effective action must be invariant under the symmetries of the theory.
I hope this helps to clarify your understanding of the Wilsonian effective action. Good luck with your QFT exam!
Related to Effective field theory in Srednicki's book
1. What is effective field theory?
Effective field theory is a theoretical framework used in particle physics to describe the behavior of particles and their interactions at different energy scales. It is based on the idea that at high energies, all possible particles and interactions are relevant, but at low energies, only a subset of these particles and interactions are relevant. Effective field theory takes into account this energy scale dependence and provides a more simplified and practical approach to understanding the behavior of particles.
2. How is effective field theory used in Srednicki's book?
Srednicki's book, "Quantum Field Theory", uses effective field theory as a tool to study the behavior of fields and particles in quantum field theory. It introduces the concept of effective Lagrangians, which are used to describe the behavior of particles at different energy scales. Srednicki also uses effective field theory to discuss topics such as renormalization and symmetry breaking.
3. What are the advantages of using effective field theory?
Effective field theory allows for a more systematic and organized approach to studying the behavior of particles at different energy scales. It also helps to simplify complex interactions and calculations, making them more manageable and intuitive. Additionally, effective field theory is a useful tool for making predictions and testing experimental results.
4. Are there any limitations to effective field theory?
Like any theoretical framework, effective field theory has its limitations. It is most applicable to systems with a large separation of energy scales, where the high-energy interactions can be decoupled from the low-energy ones. It also may not be as accurate for systems with strong interactions or in extreme conditions, such as very high energies or temperatures.
5. How can effective field theory be applied in other fields of science?
While effective field theory is most commonly used in particle physics, it has also been applied in other fields of science, such as condensed matter physics and cosmology. In condensed matter physics, effective field theory is used to describe the behavior of particles in materials and their interactions. In cosmology, it is used to study the evolution of the universe and the behavior of particles in extreme conditions, such as during the big bang.
  • Quantum Physics
  • Quantum Physics
  • Beyond the Standard Models
  • Sticky
  • Science and Math Textbooks
