I Effective mass from the Lagrangian
The discussion revolves around the derivation of effective mass from a given Lagrangian, specifically addressing the terms involving the function f dependent on velocity v. The Euler-Lagrange equations lead to the conclusion that the effective mass can be expressed as M = m + 2(∂f/∂v) + (∂²f/∂v²). A correction was made regarding the multiplication of the second derivative term, which should involve v rather than acceleration. The participants agree that the effective mass concept is valid and can relate to special relativity, while also considering the implications of a velocity-dependent force. The conversation concludes with a consensus on the nature of the effective mass and its derivation.
Malamala
Hello! I have the following Lagrangian:
$$L = \frac{1}{2}mv^2+fv$$
where ##v = \dot{x}##, where x is my coordinate and f is a function of v only (no explicit dependence on t or x). What I get by solving the Euler-Lagrange equations is:
$$\frac{d}{dt}(mv+f+\frac{\partial f}{\partial v} v) = 0$$
$$m\ddot{x} + \frac{\partial f}{\partial v}\ddot{x} + \frac{\partial f}{\partial v}\ddot{x} + \frac{\partial^2 f}{\partial v^2}\ddot{x} = 0$$
$$(m+2\frac{\partial f}{\partial v}+ \frac{\partial^2 f}{\partial v^2})\ddot{x} = 0$$
Is this correct? Can I think of this system as a particle of effective mass ##M = m+2\frac{\partial f}{\partial v}+ \frac{\partial^2 f}{\partial v^2}## moving without any force acting on it? Thank you!
You made a trivial error, ##\partial^2f/\partial v^2## is multiplied with ##\dot{x}##, not ##\ddot{x}##. Hence, in addition to an effective mass multiplying ##\ddot{x}##, there is also a ##v##-dependent force. Otherwise, the idea of effective ##v##-dependent mass seems OK to me. After all, an effective ##v##-dependent mass appears also in old formulations of special relativity. In fact, with a right choice of ##f##, you can reproduce the special relativistic ##v##-dependent mass exactly. What remains to be seen is whether the ##v##-dependent force could be interpreted as the magnetic force, I leave it as a research/exercise problem for the others.
Thank you! For the ##\partial^2f/\partial v^2## term, don't we have ##\frac{d}{dt}(\partial f/\partial v)v = \partial^2f/\partial v^2 \frac{dv}{dt}v = \partial^2f/\partial v^2 \ddot{x}\dot{x}##? So indeed I did a mistake, but that term would still contribute as an effective mass by ##\partial^2f/\partial v^2 \dot{x}## (I missed the ##\dot{x}## term before), no? Or am I doing my derivatives wrong?
You are right. There is no "force", everything can be put into the effective mass. I made an error too.
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
