Effective occupation number of photon
In summary, the conversation discusses the relationship between photon's number and photon's flux under thermal equilibrium. The occupation number is determined by the source and the photon's flux changes when it passes through an interface between two media. The equation PDOS1* ON(IN) * V1 = .PDOS2 * ON(T) * V2 + PDOS1 * ON(R) * V1 is used to describe this change, where IN, T, and R represent incidence, transmission, and reflection respectively. The concept of effective occupation number is also discussed and questioned, as well as the possibility of cancellation between reflection and velocity effects.
Jeffrey Yang
39
Hello everyone:
Here is the problem:
Under thermal equilibrium, photon's number can be described as the
photonic density of state (PDOS) * occupation number(ON).
Also, the photon's flux can be described as
PDOS * ON * effective particle velocity into certain direction ( V)
The occupation number is determined by the source, typically it will be a Boltzmann distribution characterized by the temperature and chemical potential.
When a beam scattering by an interface between media 1 and media 2, only part of incident energy can go through into the second media. If we continuously tracing the energy of the photon flux, we may can write the following equation:
, where IN, T, R means incidence, transmission and reflection respectively.
This means the occupation number of photon in the media 2 will be different to the one in media 1. Is such an effective occupation number is meaningful and this consideration is correct? Does this mean that once the reflection happens the occupation number of photon in media 2 will never reach the thermodynamic limit?
You have the effect of different reflection, but you also have the different velocity. Why are you sure they won't cancel?
If you write down the full equals, you will find that will not cancelled. The ON(T) in the second media will be a function of refractive index.
Related to Effective occupation number of photon
1. What is the effective occupation number of a photon?
The effective occupation number of a photon is a measure of the average number of photons present in a particular mode of the electromagnetic field. It is used to describe the distribution of photons within a given mode and is related to the energy and frequency of the photons.
2. How is the effective occupation number of a photon calculated?
The effective occupation number of a photon can be calculated by taking the ratio of the average number of photons in a given mode to the maximum number of photons that can occupy that mode. It is often represented by the symbol "n" and can range from 0 to 1.
3. What factors affect the effective occupation number of a photon?
There are several factors that can affect the effective occupation number of a photon, including the temperature of the system, the energy and frequency of the photons, and the presence of other particles in the system. Additionally, the effective occupation number can be influenced by the boundaries and geometry of the system.
4. Why is the effective occupation number of a photon important in physics?
The effective occupation number of a photon is important in physics because it is a fundamental quantity that can be used to describe the behavior of photons in a system. It plays a crucial role in understanding phenomena such as blackbody radiation, laser operation, and quantum optics.
5. How can the effective occupation number of a photon be experimentally determined?
The effective occupation number of a photon can be experimentally determined through various methods such as measuring the intensity of light in a given mode, analyzing the spectral distribution of the photons, or using specialized techniques such as photon counting. These measurements can then be used to calculate the effective occupation number of the photons in the system.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
