Effective Resistance of an Infinitely Long Ladder of Resistors
In summary, the effective resistance between a and b is R1 in series with the parallel combination of R2 and R.
malindenmoyer
31
Find the effective resistance (resistance between a and b) of an infinitely long ladder of resistors, as shown in the figure, each having resistance R.
http://people.tamu.edu/~malindenmoyer/fig.jpg
The point is that the input resistance which we do not yet know--call it R--will not be changed by adding a new set of resistors to the front end of the chain to make it one unit longer. But now, adding this section, we see that this new input resistance is just R1 in series with the parallel combination of R2 and R. We get immediately an equation that can be solved for R.
If you consider Req. at a'b' line, then R and Req are in parallel and other 2 R are in series with them. Simplify the circuit and solve the quadratic to find Req..
still confused, perhaps a more detailed hint?
Hello malindenmoyer,
A very important part of this is your quote,
"[Req] will not be changed by adding a new set of resistors to the front end of the chain to make it one unit longer."
So take Req as the equivalent resistance looking to the right of line a'b'.
Model Req as a single resistor if you want, at this point. Now find the equivalent resistance once you add in the extra three R resistors, between points ab and a'b'. Find the equivalent resistance of that (you'll have 4 resistors total. 2 series R, in series with an R and an Req in parallel).
But you know from your above quote, that the equivalent resistance of that new circuit (above paragraph) won't change the equivalent resistance before the 3 new resistors were added. So you can set the whole thing equal to Req. Then solve for Req.
Okay, from both of the responses, I was able to come up with this expression, am I on the right track?
[tex]R_{eq}^2-\frac{2R^2-1}{R}R_{eq}-1=0[/tex]
If correct, do I use the quadratic formula to solve?
Yes, you will be using the quadratic equation/formula for this one. But I don't think your equation is correct.
Hint: Each term in the equation (in the form aReq2 + bReq +c = 0) needs to have units of [tex] \Omega ^2 [/tex] (meaning 'a' is unitless, 'b' has units of [tex] \Omega [/tex], and 'c' has units of [tex] \Omega^2 [/tex]).
Req = 2R + [ R*Req/(R + Req).]
Now simplify and solve for Req.
FAQ: Effective Resistance of an Infinitely Long Ladder of Resistors
What is the formula for calculating the effective resistance of an infinitely long ladder of resistors?
The formula for calculating the effective resistance of an infinitely long ladder of resistors is Reff = R1 + R2 + R3 + ..., where R1, R2, R3, etc. are the individual resistances of each resistor in the ladder.
How does the number of resistors in the ladder affect the effective resistance?
The number of resistors in the ladder has a direct impact on the effective resistance. As the number of resistors increases, the effective resistance also increases. This is because resistors in series add up to create a larger overall resistance.
Can the effective resistance of an infinitely long ladder of resistors ever be less than the resistance of a single resistor?
No, the effective resistance of an infinitely long ladder of resistors will always be greater than or equal to the resistance of a single resistor. This is due to the fact that resistors in series add up to create a larger overall resistance.
How does the value of each individual resistor affect the effective resistance of the ladder?
The value of each individual resistor has a direct impact on the effective resistance of the ladder. The higher the value of each resistor, the higher the effective resistance will be. Conversely, lower values of resistors will result in a lower effective resistance.
Is there a limit to the number of resistors that can be included in an infinitely long ladder?
Technically, there is no limit to the number of resistors that can be included in an infinitely long ladder. However, in practical situations, there may be limitations due to the physical space available or the capabilities of the circuit. It is important to consider these limitations when designing a circuit with an infinitely long ladder of resistors.
