BrandonBerchtold
- 46
- 6
- TL;DR Summary
- Is it possible to accelerate a 50 picogram particle to speeds on the order of 1,000,000 meters per second (or higher) using methods typically used in particle accelerators? If so, which methods would lend themselves most practical?
Would it be practical to accelerate a 50 picogram particle to speeds on the order of 1,000,000 meters per second (in a high vacuum environment) using methods typically used in particle accelerators? 2 methods that come to mind are a series arrangement of parallel pate accelerators and a moving wave microwave cavity linear accelerator.
I am guessing the parallel plate accelerator design would need impractically high voltages to achieve high enough speeds due to the high mass to charge ratio of the particle being accelerated? My rough calculations are below:
Assumptions:
- Particle is charged to same voltage as first accelerator plate
- V = Applied Voltage to charge particle = Parallel plate accelerator total voltage difference between first and last plate
- Particle has diameter of 10 microns
- Particle density is 86 kg/m^3
Charge on sphere = 4 * PI * ε0 * Sphere radius * V
Source: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/potsph.html
0.5*m*velocity^2 = Charge on sphere * V
V = Sphere radius * velocity * 1,272,342
V = 0.000,005*1,000,000*1,272,342 = 6,361,710 volts
Nearly 7 Megavolts seems pretty high for a parallel plate accelerator right?
My concern with the microwave linear accelerator is that usually electrons enter the accelerator going on the order of 0.4c and match the speed of the wave in order to get caught in the trough between wave peaks before the wave accelerates to relativistic speeds. Could such an accelerator be tuned to capture 50 picogram particles traveling at much much slower speeds and accelerate them to 1,000,000 meters per second? I know close to nothing about how these accelerators work so any input is appreciated.
Are there other types of accelerators that would be better suited for such an application?
Assumptions:
