Effects of a Motor on sensitive electronic components
In summary, the poster is inquiring about how to calculate the effects of a motor and switching current on surrounding electronics. They mention using a PWM signal for the motors and have a GPS unit and magnetometer that require specific power supply fluctuations. They want to know how to calculate the effects of the motors and cables supplying them on the components and figure out the minimum distance needed to place them. They also mention the importance of proper power wiring and grounding to avoid ground loops and using shunt diodes and bypass capacitors. They suggest using a voltage regulator for the GPS unit and shielding interconnect cables to prevent damage to circuits.
Xarren
Hey, my first post on here, just wanted to ask how to calculate the effect of a motor, and a switching current in the wires supplying the power on the surrounding electronics.
The two motors will be supplied a PWM signal of 20Khz frequency, 5amp, 7v2 at 80% duty cycle. This is part of a project, where I will have a GPS unit which requires a maximum of 50microvolt fluctuations in its power supply - any more and it will not get a lock, and a magnetometre which is used for a heading and reference system.
How would I calculate the effects of those motors on those components? Also how would I calculate the effect of the cables supplying the motors on those components? I need to work out the minimum distance I need to place them from the motors, and should that not be achievable due to project size restrictions, I guess I may need to shield them.
Thanks,
X
EDIT: Just realized there is an electronic engineering section of the forum, if an admin happens to read this, could you please move my thread? << Done. >>
I don't know about no calculating, but in general you need to be very careful with your power wiring and grounding. Run separate lines from the main power source to the motors. Ground everything at one point at the main power and avoid "ground loops" where a ground wire connects to that point from more than one direction. Use shunt diodes on the motor windings to minimize inductive kick-back. Bypass, bypass, bypass, capacitors in both large and small values -- small, like .1uf ceramic, for high frequencies. If possible put a voltage regulator at the GPS unit and run the motors off the raw supply. Shield interconnect cables, especially inputs, and especially remember the ground loop thing here.
Proper prophylaxis saves circuits...
FAQ: Effects of a Motor on sensitive electronic components
What are the potential risks of using a motor near sensitive electronic components?
The main risk is electromagnetic interference (EMI) which can cause malfunctions or even permanent damage to electronic components. This is because motors produce strong magnetic fields and electrical noise that can disrupt the normal functioning of sensitive electronics.
How can I prevent the negative effects of a motor on sensitive electronic components?
There are several measures you can take to reduce the impact of a motor on electronic components. These include using shielding materials such as metal enclosures or ferrite beads, keeping a safe distance between the motor and electronics, and using filters or surge protectors to block EMI.
Are there any specific types of motors that are less likely to cause interference with electronics?
Stepper motors and brushless DC motors are generally considered to be less likely to cause EMI compared to brushed DC motors or AC motors. This is because they have more controlled and smoother electrical signals.
Can the effects of a motor on sensitive electronic components be tested before installation?
Yes, there are specialized tools and equipment available for testing EMI and its potential effects on electronic components. These tests can help identify potential issues and allow for adjustments to be made before the motor is installed.
What should I do if I notice interference from a motor on my electronic components?
If you notice interference or malfunctions in your electronic components due to a nearby motor, you should first try to identify the source of the interference. Then, you can take steps to reduce or eliminate it, such as repositioning the motor or adding shielding materials. If the issue persists, it may be necessary to consult with an expert or consider using a different type of motor.
