Effects of different types of vacuum at equal pressure
In summary, Firestorm believes that a water-based pump will provide a better outcome than an air-based pump for a patient with Peyronie Disease. He argues that the expansion in the penis will be more noticeable with water than with air, and that the higher compressive force of water will cause more length and girth expansion.
Profan
Hi everyobdy.
First, forgive me for mistakes, since English is not my native language.
I'm going to ask a kinda strange question, so let me add a short premise. I'm a first grade MD, andrology will be my area of expertise. I have to give an advice about a patient who has Peyronie' disease (penis with a pronounced curve, basically) . This disease has been treaten with chemicals and mechanical therapy; more specifically, I'm going to prescribe a vacuum device.
One of my fellows argues that water-based pumps will provide a better outcome. His argument is that, for any given level of negative pressure, say 5hg, the expansion in the penis will be certainly more noticeable if the vacuum is generated by water than if generated by air.
I do understand that, being air not expandable at that pressure (differently than air) the space created, so to speak, by the water which is pulled out, will be filled entirely with the penis; where I differ, is the final outcome, after about 20 minutes : my reasoning is that, slowly (let's suppose the pressure has dropped to 3hg in both scenarios), the density of water will posite a limit to the expansion of the penis; since water is hard to compress, where air is not, after a while the penis will have to fight an higher compressive force if imersed in water than if in a air-generated vacuum.
I do believe also that the same higher compressive force of water, in hand with the bouyancy, will cause more length expansion in the water vacuum than in air and more girth expansion in air than in water (this is a secondary question, though).
Hope my question is clear.
I'd like to hear a very simple explanation and if possible an opinion from somebody whith an operative, professional experience in a related field.
Thanks to everybody in advance for the help.
I wouldn't have the slightest idea how to help you with the biological aspect, but generally speaking, if something experiences a pressure gradient then that is independent of the medium in which it is immersed. In other words, if you maintain a negative pressure gradient (pressure in container is lower than outside) then a fluid or gas will want to expand to fill this space, in your case blood.
As such I don't believe the intermediary fluid matters whatsoever from a pressure standpoint; pressure is pressure. If you picture a water balloon, then that can be our model of the human body. Now you lop off the front part of a cringe so you only have the back plunger part; sealing this up against the balloon and drawing it back would cause the balloon to expand out. If the cringe was full of fluid then you would actually be able to achieve a higher pressure gradient than with air BECAUSE the fluid is incompressible.
The biggest thing to understand is that there's no such thing as negative pressure. A fluid always pushes against the walls of its container. A vacuum pump works because the air outside pushes against the balloon or the body harder than the air from the pump, thus the balloon or body is pushed into the pump by the outside air.
So in conclusion, I think the water or other liquid would work better, assuming that getting a larger pressure difference is the goal. Because there is a pressure applied the water should be sucked out as the organ in question expands, so the incompressibility of water is a benefit.
Edit: and by all means don't take my word for it, try the balloon experiment yourself. You *should* see that drawing the plunger back a given amount causes more deformation if the cringe is liquid filled rather than air filled, due to air being incompressible.
Yes I do know that 'negative pressure' is technically not correct Firestorm, I used it like an abbrevation, kinda a slang to save words.
Thanks for your answer.
Any other reply?
Related to Effects of different types of vacuum at equal pressure
1. What is the purpose of studying the effects of different types of vacuum at equal pressure?
The purpose of this study is to understand how different types of vacuum affect the overall pressure within a given space. This can help us determine the most efficient and effective ways to create and maintain a vacuum for various applications, such as in industrial processes or scientific experiments.
2. How do different types of vacuum affect the pressure within a space?
Different types of vacuum, such as mechanical pumps or cryogenic pumps, use various methods to remove air and other gases from a space. This can create different levels of pressure within the space, which can impact the overall effectiveness and functionality of the vacuum.
3. What are the potential benefits of using different types of vacuum at equal pressure?
By studying the effects of different types of vacuum at equal pressure, we can determine which type of vacuum is most suitable for a specific application. This can lead to more efficient and cost-effective processes, as well as improved product quality and safety.
4. Are there any potential drawbacks to using different types of vacuum at equal pressure?
One potential drawback is that some types of vacuum may be more expensive or require more maintenance than others. Additionally, certain types of vacuum may be better suited for specific applications, so using them at equal pressure may not yield the most optimal results.
5. How can the results of this study be applied in real-world situations?
The results of this study can be used to inform the design and implementation of vacuum systems for various applications, such as in manufacturing, research, and medical environments. They can also help improve our understanding of how different types of vacuum interact with different materials and substances, which can have practical implications in various industries.
9K
  • Mechanics
