Effects of Intermolecular Forces?
In summary, for a van der Waals gas, the London dispersion forces cause the gas particles to be attracted to each other, while the law of excluded volume provides repulsive forces. These characteristics have opposite effects on pressure, volume, and temperature. Attractive intermolecular forces cause a decrease in pressure and volume due to particles clumping together, but an increase in temperature due to greater kinetic energy. In contrast, repulsive forces would have the opposite effect. Additionally, a decrease in displacement caused by attractive forces would outweigh the increase in velocity from inelastic collisions, resulting in a decrease in temperature. It is important to note that attractive forces are not the same as intermolecular forces and can cause substances to stick together.
Gwozdzilla
81
For a van der Waals gas, there are London dispersion forces causing the gas particles to be attracted to each other while the law of excluded volume provides repulsive forces. How do each of these characteristics effect the pressure, volume, and temperature of the gas?
I assumed that for the attractive intermolecular forces, pressure and volume would decrease because the particles would clump together (smaller volume) and hit the sides of their container less (less pressure). At the same time, I think that temperature would increase because the molecules would have a greater kinetic energy from bumping into each other. Thus, I believe the opposite would be the case for the repulsive forces.
Is this actually the case?
The KE would NOT increase if IF forces increased, think about it in terms of particles, if IF increase, then the displacement between the particles decrease, a decrease in dispacement causes a decrease in velocity and thus KE so will tempature would decrease.
If IF forces increase then
Volume=decrease
Pressure=decrease
know that the if KE>IF the state of matter is a gas, and also that if IF>KE the state of matter is a solid and lastly that if IF>=KE the state of matter is a liquid.
Are you sure that a gas with high intermolecular forces would not still fill all the available volume in any container you put it in?
gases have low intermolecular forces, that is why they are free to move around .A property of a gas is that they fill the volume of the container so of course they would.
Sorry we cross posted - the question was intended for OP.
NP, hope that helped the OP though, funny that you are helping me on my thread I just posted about resonance.
Volume=decrease
Pressure=decrease
Do you mean that attractive intermolecular forces will decrease volume, pressure, and temperature, while repulsive molecular forces would increase volume, pressure, and temperature? Why would a decrease in displacement, which would cause a decrease in velocity, outweigh the increase in velocity caused by inelastic collisions between the molecules?
There are no repulsive intermolecular forces, maybe you mean the repulsive elctromagnetic forces? when we analyze the molecules we assume that their colisions are elastic. A decrease in displacement causes velocity to decrease, if velocity decreases then KE must decrease becasue KE=1/2mv^2. Remember that is KE is greater than IF than the particles can escape the substance via evaporation for example. Furthermore the attractive forces are not the same as intermoleclar forces, they cause other substances like water on a table to want to stick together.
Related to Effects of Intermolecular Forces?
1. What are intermolecular forces?
Intermolecular forces are the attractive forces that exist between molecules. They arise due to the electrostatic interactions between the positively charged nuclei and the negatively charged electrons of neighboring molecules.
2. What are the different types of intermolecular forces?
The three main types of intermolecular forces are London dispersion forces, dipole-dipole interactions, and hydrogen bonds. London dispersion forces are the weakest type of intermolecular force and occur between all molecules. Dipole-dipole interactions occur between polar molecules and are stronger than London dispersion forces. Hydrogen bonds are the strongest type of intermolecular force and occur between molecules containing hydrogen bonded to a highly electronegative atom, such as nitrogen, oxygen, or fluorine.
3. How do intermolecular forces affect the physical properties of a substance?
Intermolecular forces play a crucial role in determining the physical properties of a substance, such as boiling point, melting point, viscosity, and surface tension. The strength of intermolecular forces determines how tightly the molecules are held together, which in turn affects the amount of energy required to break these forces and change the physical state of the substance.
4. How do intermolecular forces contribute to the solubility of a substance?
Intermolecular forces also play a significant role in determining the solubility of a substance in a particular solvent. For a substance to dissolve in a solvent, the intermolecular forces between the solute and solvent molecules must be strong enough to overcome the intermolecular forces between the solute molecules. Polar solvents, for example, have strong intermolecular forces and can dissolve polar substances, while nonpolar solvents can dissolve nonpolar substances.
5. How does temperature affect the strength of intermolecular forces?
The strength of intermolecular forces decreases with increasing temperature. This is because at higher temperatures, molecules have more kinetic energy and are able to overcome the attractive forces between them, causing them to move further apart. As a result, substances with weaker intermolecular forces tend to have lower boiling points and melting points compared to substances with stronger intermolecular forces.
  • Other Physics Topics
  • Classical Physics
  • Classical Physics
  • Thermodynamics
  • Mechanical Engineering
