Effects of Lens Element Aberrations on a Fully Corrected Lens Image
In summary, Leitz Summicron 50 is a highly corrected lens known for its beautiful image effects. The legend surrounding this lens suggests that its internal elements and their spherical aberrations contribute to these effects. However, for a highly corrected lens, internal aberrations should have minimal impact on the final image. It is possible that the designer, Mandler, intentionally used elements with high spherical aberration and then corrected for it in the final compound lens. Overall, the design of a well-corrected lens involves many techniques and considerations, and the amount of aberrations in individual elements does not necessarily reflect the final image quality.
Mustafa Umut
34
Leitz Summicron 50 is one of the extremelly well corrected lens in the world. Legend says about this lenses internal elements and their spherical aberrations was responsible of lot of beatiful effects on image.
For highly corrected lens image , does high internal aberration really effects the image or is it a legend ?
Thank you,
Mustafa Umut Sarac
Istanbul
Science news on Phys.org
Forgive me, I partially completed an optics degree but I don't think I ever got far enough to learn about 'internal' aberrations. What are those?
If the lens was extremely well corrected, then I presume it has negligible spherical aberration, which wouldn't have any effect on the image other than reducing image blur.
Drakkith, Thank you very much for your answer.
There are two things.
First , glass lens elements
And second , completed camera lens made up with these above glass lens elements.
Two ways to design first ,each glass lens elements.
A - Fully correct each of glass lens element
B - Allow some aberrations for glass elements - first- and than correct everything to second completed lens .
Why Leitz lens designer Mandler used extremelly high spherical aberration for the two lens glass elements , one is in front of aperture , second in behind of aperture.
What are their effects to image. COMPLETED camera lens was extremelly lowest aberrations , even no aberration.
  • Skeptical
Likes davenn
Okay, so internal aberrations are just the aberrations from a single element, or from the combination of some of the elements that makes of the optical system.
This isn't possible. No single element can be completely corrected for all possible aberrations. Only the combination of multiple elements of different shapes and different materials can correct for all aberrations.
There are many, many different ways to design a well-corrected lens, so it's difficult to say that high internal aberrations result in low overall aberrations. Because it's not strictly true. It all depends on the exact number, shape, size, composition, and placement of the different elements. All that can really be said is that the lens was designed to be extremely well corrected and the designers used many different techniques to do this, one of which was using elements with high individual spherical aberration that was corrected for once the elements were put together into a compound lens.
Likes berkeman and davenn
Drakkith , Thank you very much for your answer.
Do internal spherical aberration have a targeted image quality ? Does spherical internal aberration effect the image or all goes finally corrected for compound lens and have no effect on image quality ? We talk about leitz summicron r 50mm
Only in the sense that you have an overall 'acceptable limit' that you choose when you first start designing the lens, and you have to choose how much spherical aberration each element has so that the final result is less than your acceptable limit.
The spherical aberration of one element can be corrected by another element with opposite spherical aberration, or by a combination of different amounts of spherical aberration from multiple elements. This is true in general for other aberrations as well.
It's true regardless of the exact optical system. These are general properties and techniques of optical system design.
Mustafa Umut said:
Summary: Internal Aberations and Image Formation of Fully Corrected Lens
It isn't clear what your question is about. You seem to be suggesting that it may be better to start with a first element that is not as good as possible and to use other elements, also with only 'fair' performance to correct the aberration of the first one. You need to consider the Chromatic Aberration as well - which can only be corrected by using multiple elements, afaik.
There is an analogy with RF band pass filters which can have extra group delay correcting networks added to the frequency selecting stage. In that sort of design, achieving an overall good band pass characteristic with good group delay performance can involve an imperfect band pass stage in order to allow a good group delay correcting stage. The overall band pass characteristic will be good.
PS what is your overall level of understanding of lens design?
That's actually a valid design method since the 'best' optical elements are typically very expensive and made out of 'exotic' materials and in shapes that are difficult to fabricate. You can still achieve perfectly acceptable results using relatively inexpensive materials and shapes for the elements.
Sophiecentaur,
I think delay correcting relates to transfer function ?
Let me try to explain why I asked my first question,
Legend says high spherical aberrations at some elements of summicron - its highly corrected lens at final - makes some beatiful images at the photography.
I think Sophiecentaur , you accept this , I think you relate above errors in design to delay correcting and finally to transfer function where transfer function dictates the frequency and time relation completely.
Lets talk about high spherical aberration and other aberrations.
Do they act to transfer function differently or the same ?
How can I learn which aberration how effect the transfer function ?
That's introducing a new variable, though. I thought we were assuming a given glass quality. "Perfectly acceptable" is not a well defined description, I think. Leitz lenses will have been made to a spec that's somewhat higher than acceptable and material costs could be anything. You're dead right about the situation with semi-pro lenses though. I just though about wall building in which a good 'bricky' can use rough bricks but still keep the wall as level as needed. Otoh, I can make a sloping wall out of even the best bricks available.
I think the OP needs to be considering CA as well as SA for an explanation of what's done in lens design.
I found this well-written discussion about Leica photography lenses:
https://www.overgaard.dk/pdf/Leica-M-Lenses-Their-Soul-and-Secrets_en.pdf
In it is a lot of detailed description about specific design trade-offs for nearly every single lens Leica makes, and I recommend that you carefully read as much of this as you can.
As has been pointed out, the whole concept of aberration balancing is to combine contributions from individual elements to result in much lower lens aberrations. But, some lenses allow user-control of lens aberration (Nikon calls it 'defocus control'), specifically control of spherical aberration:
https://kenrockwell.com/nikon/images1/135mm-dc/patent-5841590.pdf?vid=USPAT5841590https://photo.stackexchange.com/questions/7044/how-do-soft-focus-or-defocus-control-rings-work
The PSF images in the stackexchange site are particularly helpful to understand your specific question about control of spherical aberration.
FAQ: Effects of Lens Element Aberrations on a Fully Corrected Lens Image
What are lens element aberrations?
Lens element aberrations refer to the imperfections or deviations in the shape or position of the lens elements in a camera lens. These aberrations can cause distortions, blurring, or other unwanted effects in the resulting image.
How do lens element aberrations affect image quality?
Lens element aberrations can significantly impact the sharpness, clarity, and overall quality of an image. They can cause distortions, color fringing, and reduced contrast, resulting in a less sharp and less detailed image.
What is a fully corrected lens image?
A fully corrected lens image is one in which all lens element aberrations have been minimized or eliminated through the use of specialized lens elements and design techniques. This results in a high-quality image with minimal distortions and maximum sharpness and clarity.
How can lens element aberrations be corrected?
Lens element aberrations can be corrected through the use of specialized lens elements, such as aspherical or low-dispersion elements, and advanced lens design techniques. These elements and techniques help to reduce or eliminate the imperfections in the lens, resulting in a more accurate and high-quality image.
Are lens element aberrations present in all lenses?
Yes, lens element aberrations are present in all lenses to some degree. However, the level and impact of these aberrations can vary depending on the quality and design of the lens. High-quality, fully corrected lenses will have minimal aberrations, while lower-quality lenses may have more noticeable aberrations in their images.
