Effects of relativistic mass on astronaut
In summary: Sure you are. You are traveling near to the speed of light compared to a reference frame that is traveling near the speed of light relative to...you.
SpiderET
82
Lets assume we have a starship which is flying from Earth to star XY which is in distance for example 100 lightyears. The computer of that ship is programmed that way, that it maintains acceleration 1 g. After some time the speed of ship reaches some significant part of speed of light and to maintain the acceleration, the engins must burn more and more fuel to maintain 1 g. But there is also the effect of time dilation, contraction and increase of mass.
Lets say the ship reaches 87%of speed of light, which would mean that there are some significant relativistic effects for example the relativistic mass would double compared to original rest mass of the ship.
Now I am getting to the question: Would the astronaut inside the ship feel that he weights 160 kilograms when his original weight was 80 kilograms?
What I know, the accepted consensus is that he would not feel the increase of weight, because he is in his own reference frame inside the ship. But is this view hardwired in quotations of SR and GR or is this just a philosophical point of view which was never confirmed by any experiment?
You can perform the experiment without leaving your chair by changing the reference frame in which you describe your own motion to anyone moving at 87%c relative to you (or even 99.99999999%c for that matter). Can you feel yourself being crushed by your suddenly-increased weight?
You are talking about something completely different and to avoid such misundestanding I have described the situation of the astronaut in detail.
OK, to account for the difference: Consider a transformation where as time passes, you go to a frame moving a bit faster than the last one w.r.t. you. Do you feel something now?
Not at all: the point is that choices of reference frames are largely arbitrary. But what matters to you is that you are stationary with respect to your ship and scale.
And yes, this is built into physics and long predates Einstein, though it is one of the two postulates of SR. It is called the principle of relativity.
I don't feel anything special, because I am not near to speed of light compared to any reference frame.
OK, but let's say I am saying that the astronaut feels like he is having 160 kilograms and I am using the SR quotation to calculate his weight (relativistic mass increase). Is there any experimental evidence against it or is this just based on philosophical explanation based on principle of relativity? And please keep in mind that standard experiments like Michaelson Morley null result would not disprove possibility of this astronaut having 160 kilograms weight.
That's most emphatically not true. There's an infinite number of reference frames in which you're traveling at arbitrary speeds. Particlular examples include the frames of muons created by solar wind in the upper atmosphere of Earth, or of the particles accelerated to near c in any of the many particle accelerators.The built-in bit in the equations is the gamma (Lorentz) factor $$\gamma=\frac{1}{\sqrt{1-\frac{V^2}{c^2}}}$$ present in all relativistic equations. In a stationary frame it's alwas 1 (as V=0). Since the astronaut is measuring his own weight in a frame in which he's stationary there can be no relativistic effects he could ever notice with regards to himself.
Sure you are. You are traveling near to the speed of light compared to a reference frame that is traveling near the speed of light relative to you.
Yes, you are. There are an infinite number of perfectly legitimate frames where your current speed is within one part per billion of the speed of light.
That isn't true. You are near the speed of light in an infinite number of reference frames.
SpiderET said:
OK, but let's say I am saying that the astronaut feels like he is having 160 kilograms and I am using the SR quotation to calculate his weight (relativistic mass increase). Is there any experimental evidence against it...
Yes, tons. SR and GR are exquisitely well tested.
That means that quotations of SR and GR are giving good predictions compared to experiments and astronomical reality. But the question was different. I could use SR quotation to calculate that this increase of relativistic mass was leading to 160 kilograms of weight of astronaut. This would be not in line with relativity principle, but is there any specific experiment which would prove this calculation wrong?
You're not paying attention. Let me give you an example:
Imagine spaceship A and B moving w.r.t. each other with velocity v(which is comparable to that of light). According to SR, all inertial frames are equivalent and there is no preferred inertial frame and so each of A and B has equal right to consider itself as stationary and the other one as moving. So A says that he's at rest and B is moving and so A sees relativistic effects happening for B. But B can also consider consider himself as being at rest and A as moving and so B sees relativistic effects happening for A. For A, everything is as before for things in its own reference frame and the same for B.
Yes, decay rates of highly relativistic muons and electrons is an example. A more massive muon or electron would be less stable than an actual muon or electron. In the case of electrons, it would lead to spontaneous decay of relativistic electrons, and in the case of muons it would lead to faster decay than the experimentally verified decay rates.
Thank you very much, this is exactly what I needed. I will check it.
ALL predictions of Relativity, including relativistic mass change(apologies for using the out of date term), are exquisitely well tested.
Also see https://www.physicsforums.com/threads/what-is-relativistic-mass-and-why-is-it-not-used-much.783220/
This seems to me a typical misunderstanding based on the relativistic mass concept.
With the right analysis, you can get rid of a lot of these factors. Interestingly enough, though, people seem to resist doing this, even when they are told how it can be accomplished.
How do you do this? Well, the first key observation is this. The value of the coordinate acceleration of the ship depends on the observer, or the observers frame of reference. This is probably the most important step to working the problem. The notion of "proper acceleration" would also be useful to understand the problem, but it appears to be unfamiliar to many readers.
Now I'll start some analysis using a 'question and answer' format.
1) We noted that the acceleration of the ship depends on the observer. For w hat observer, in what frame of reference, is the coordinate acceleration of the ship equal to specified value of 1g.
answer: this frame of reference is the reference frame of the ship. Note that this is the only frame where the proper acceleration is equal to the more familiar coordinate acceleration.
2) What is the "relativistic mass" of the ship in this frame.
answer: it is equal to the rest mass of the ship.
3) Doesn't this make the relativistic mass pretty much irrelevant to solving the problem
answer yes
4) Why do people go on and on about the relativistic mass, then, if it's really not that useful in solving the problem
answer beats me :-). If you find out, let me know. I do suspect that the usual reason for this focus on relativistic mass is related to a belief that saying "it requires infinite energy to accelerate close to the speed of light" (true) is the best way to describe why objects can't reach the speed of light (probably false).5) Wait - this is getting a bit off topic.
answer: sorry about that, couldn't resist.
6) OK, let's get back on track. We've determined that we find the acceleration of the ship in its own frame, where we don't need to worry about relativistic mass, and we only need its non-relativistic mass and it's thrust. How do we go about finding the acceleration (and velocity, and position) of the ship versus time in a wholly inertial reference frame - i.e the initial inertial reference frame the ship was in before it started accelerating?
answer: This starts to get a bit mathematical, but the math required doesn't need any dynamics at all, only kinematics. The kinematics required are the Lorentz transform and perhaps the velocity addition formula. See http://en.wikipedia.org/wiki/Velocity-addition_formula
In some amount of ship time, (also called proper time), ##\tau##, we know that the ships velocity increases by a multipled by ##\tau## in the ship frame. The velocity equation in general says that we add two velocities v1 and v2 using the relativistic formula
v_tot = (v1 + v2) / (1 + v1 v2 / c^2)
In this case we have v1 = ##v_{ship}## and v2 = ##a \tau## so we get
[tex]
\frac {v_{ship} + a \, \tau}{1 + v_{ship} a \tau / c^2}
[/tex]
where## v_{ship} ## is the current velocity of the ship
a is the proper acceleration of the ship (measured in the ship frame)
##\tau## is the proper time of the ship (measured in the ship frame)
c is the speed of light
If you then consider ## v_{ship}## to be a function of ##\tau##, you can write a differential equation and solve it as a function of ##\tau##. You would still need to do some work to express ##\tau## in terms of what you probably want, which would be "t", the amount of coordinate time in the initial inertial reference frame of the ship before it started accelerating.
You can use the well known time dilation equation ##d\tau = {dt}{\sqrt{1-v^2/c^2}}## to relate t and ##\tau##
This gets detailed enough that I'll give a link to the answer instead of trying to wade through it - see "The Relativistic Rocket" http://math.ucr.edu/home/baez/physics/Relativity/SR/rocket.html
The end result for the distance, velocity, and acceleration of the ship in an inertial where the ships initial velocity at t=0 is 0 is:
distance = ( (c2/a) (sqrt[1 + (at/c)2] - 1)
velocity = at / sqrt[1 + (at/c)2]
The reference doesn't give acceleration, we can derive it easily enough by differentiating velocity with respect to t
acceleration = a / [1 + (at/c)^2)] ^ (3/2)
Note that while the proper acceleration a of the ship in its own frame remains constant, the coordinate acceleration drops off as time increases, becoming lower and lower.
No, the accepted consensus is that he would not feel the increase of weight, because the computer controlling the rocket is programmed to maintain a constant acceleration of 1 g, by which you appear to mean a constant rocket thrust. That constant rocket thrust means the astronaut will feel a constant weight.
If, OTOH, the computer were programmed to keep the rocket's coordinate acceleration constant in the frame in which the rocket was originally at rest, then the computer would have to constantly increase the rocket thrust, and so in this case, the astronaut would feel a constantly increasing weight. But that's a different scenario from the one you proposed.
The weight the astronaut feels does not depend on his relativistic mass; it depends on the force being exerted on his feet by the rocket, i.e., on the rocket thrust. An astronaut with the same relativistic mass (in a given frame) could have any weight from zero to infinity, depending on the thrust being exerted by his rocket. For example, if the rocket is turned off, exerting zero thrust, the astronaut feels zero weight, even though he is moving at 87% of the speed of light relative to a chosen frame.
I don't think this is relevant as a response to the OP, because the "mass" that comes into play in decay rate calculations is invariant mass, not relativistic mass, and the OP is asking about relativistic mass. (The muon experiments do demonstrate that decay rate is independent of proper acceleration to a high degree of precision, but as I noted above, proper acceleration has no relationship to relativistic mass.)
As I understand it, he is not asking about either relativistic mass or invariant mass, both of which are well defined in relativity and which behave as described by you and others .
He is asking about a concept of mass that doesn't exist in relativity, one which increases like relativistic mass but has measurable physical effects in the rest frame like invariant mass. The concept of mass that he is asking about explicitly violates the first postulate, so it is neither relativistic nor invariant mass.
I think that what I posted is one of many valid ways to show that this concept of mass is wrong.
Hm, ok, that wasn't how I was reading the OP but I can see that it's a possible reading. I was reading the OP to be under the misapprehension that weight depends on relativistic mass, when in fact it depends on proper acceleration, which is independent of both kinds of mass (invariant and relativistic).
I agree.
Hmm, yes, I could see how that is another way to read the OP's question. I guess that is one inherent problem with such questions. It is hard to communicate the question even if the poster actually has an unambiguous question in mind, which is often not the case.
Not sure what the OP has in mind, but if he answers a few questions it might help. (Or maybe not, but it seems like a start).
1) Is relativistic mass the property of an object, or does it depend on both the object and the choice of a reference frame?
2) What is the velocity of an object in a reference frame in which it is at rest?
3) If the velocity of an object is zero, what is the relationship between its relativistic and rest (and/or invariant) mass?
[add]
4) Is velocity a absolute quantity, or a relative quantity that depends on the reference frame
5) Are there any reasons to prefer one reference frame over another? Or can a problem be worked in any inertial frame you choose?
The astronaut inside of the spaceship would not feel any difference in mass, time, or any contraction. This is because he is observing and measuring from his frame of reference. From his frame of reference, he is not moving at all but the objects outside of his spaceship are zooming past him at 87% the speed of light. They would appear heavier if measured, and would seem to be contracted. It is only to an outside observer would it be that he is heavier if measured and that the spaceship and the astronaut have contracted. I hope this helps :)
Related to Effects of relativistic mass on astronaut
1. How does relativistic mass affect astronauts in space?
The effects of relativistic mass on astronauts in space are mainly related to the increased velocity they experience while traveling at high speeds. As an object approaches the speed of light, its mass increases, causing the astronaut to feel heavier and experience a decrease in their sense of time passing.
2. What are the physical implications of relativistic mass on astronauts?
The physical implications of relativistic mass on astronauts include an increase in their inertia, making it more difficult to accelerate or change direction, as well as an increase in their body temperature due to the conversion of kinetic energy into heat. They may also experience time dilation, where time appears to pass slower for them compared to those on Earth.
3. How does relativistic mass affect gravitational pull on astronauts?
Relativistic mass does not affect the gravitational pull on astronauts. Gravity is not dependent on an object's mass, but rather its mass and distance from another object. However, the increased mass of the astronaut may make them feel a stronger gravitational pull from other objects.
4. Can the effects of relativistic mass on astronauts be measured?
Yes, the effects of relativistic mass on astronauts can be measured through various experiments and observations. For example, the gravitational redshift effect, where the light from an object appears to shift towards the red end of the spectrum due to its increased mass, can be measured by observing the light from a star as an astronaut travels towards it at high speeds.
5. How does relativistic mass affect the energy requirements for space travel?
The increase in relativistic mass of an astronaut at high speeds will require more energy to accelerate and maintain their velocity. This is due to the equation E=mc^2, where the energy needed is directly proportional to the mass. This means that as the mass of the astronaut increases, so does the energy needed to move them.
9K
