Effects of various voltage drops in passive circuits
In summary, the voltage drop due to a resistance is determined by resistance*current, the voltage drop due to an inductance is determined by inductance*change in current/change in time, and the voltage drop due to a capacitance is determined by charge stored / capacitance, assuming applied voltage is constant. The relationship between the voltage drop and current in an inductor is non-linear, and the energy in a magnetic field is proportional to the rate of change of current and the inductance. This is represented by the equation (1/2)*L*(I^2). The potential energy in a magnetic field is also proportional to the current, but the relationship is not linear due to the presence of an external magnetic field.
kmarinas86
979
Voltage drop due to a resistance: Determined by resistance*current
Voltage drop due to an inductance: Determined by inductance*change in current/change in time
Voltage drop due to a capacitance: Determined by charge stored / capacitance
Assuming applied voltage is constant:
Question 1: Must the voltage drop due to an inductance always fall by one volt every time the voltage drop due to a resistance goes up by one volt?
My thoughts: I don't think so, not if there's a capacitance.
Question 2: Must the development of the magnetic flux of circuit correspond to the increase in the voltage drop due to a resistance, or is it more properly related to the time-integrated voltage drop due to inductance?
My thoughts: Basic teaching implies the former (i.e. when they say "the current produces the magnetic field"), but perhaps more advanced teachers refer to the latter (e.g. "the increase in current produces the magnetic flux at a rate proportional to the inductance"). When capacitance is ignored it would be safe to assume that decrease in the voltage drop due to inductance implies a 1-to-1 increase in the voltage drop due to resistance.
Question 3: If one takes the derivative of each of the three types of voltage drops (i.e. due to resistance, inductance, and capacitance) with respect the derivative of length, which of those three quantities is useful, and if so, in what way?
My thoughts: Maybe each quantity has something to do with how effects of the applied electric field are allocated at each point in the circuit?
Have you had e-m field theory yet? If not, these issues will get covered when you do take e-m fields.
Regarding the question, "does the current produce the magnetic field?", all I can say is what Maxwell's equations reveal. Under *time-changing* conditions, the electric and magnetic fields cannot exist independently. Likewise with the circuit quantities current and voltage. Under static conditions, a steady dc current has a static magnetic field associated. If, however, the current is "ac", or time-varying, then there must be a non-zero voltage and non-zero electric field as well as the time-varying magnetic field. As far as the current producing the magnetic field goes, it is very hard to say what causes current, H fields, E fields, voltage, charge, flux, etc. There is no real "pecking order". Maxwell showed us that when the energy is static, we can have a static current and H/B field with zero voltage and E/D field. Or a static voltage and E/D field exists with zero current and H/B field. This is only for static energy conditions.
Under dynamic energy conditions, all of the above mentioned quantities are non-zero. That's the crux of Maxwell's equations.
Does this help? BR.
Does this help? BR.
It's very informative as it helps explain the non-linearity of the situation.
If I think for a moment...
The change of energy in the magnetic field depends on the change of current, right?
The derivative of current squared with respect to time would be 2*current*(change of current/change in time) right?
Now, the voltage drop due to inductance is equal to inductance * (change of current/change in time), so the derivative of current squared is: 2*current*voltage drop due to inductance/inductance
Since the energy in a magnetic field is equal to (1/2)*inductance*current^2, the resulting rate change of the energy in the magnetic field seems to be equal to current*voltage drop due to inductance.
However, the potential energy with respect to an external magnetic field is proportional to current*flux area*b-field (or IAB for short).
What is the proper way to distinguish between the two apparently different energies (one proportional to current squared, and the other, seemingly proportional to current to the first power?).
Actually, IAB, which equals I*phi, since phi = A*B, is not the first power of current, but the square. The definition of inductance is N*phi = L*I = N*A*B. Integrating N*phi dI gives 0.5*L*(I^2). So "IAB" is not a 1st power relationship since "AB" which equals "phi" contains another factor of I, making the relationship 2nd power.
I thought A was the area of the turns and B an external field. Does current somehow affect B? I find it hard to believe that it would affect A. I thought [itex]U=-\vec{\mu}\cdot\mathbf{B}[/itex] was the energy potential of the magnetic field while [itex]\vec{\tau} = \vec{\mu} \times\mathbf{B}[/itex] was the torque (energy and torque seem to be separated by 90 degrees). But if you still meant B as the external field, I am at a loss to explain how phi would be proportional to current.
So if I increase I, A*B should increase proportionally then (assuming that L/N is constant). When then of the formulas above?
Increasing I increases B as well, but not A. A is the area which is fixed.
I'm having trouble following your reasoning. Could you state a specific problem with conditions? Then we can communicate as I don't know what you're asking right now. BR.
http://physics.bu.edu/~duffy/PY106/MagForce.html
B is supposed to be the external magnetic field (for example see:http://ocw.mit.edu/NR/rdonlyres/Physics/8-02TSpring-2005/DADE0D33-296E-405C-B8AD-CC42AB16AF46/0/solving05.pdf )
I don't know how the external magnetic field is affected by the current, because if the external magnetic field is REALLY strong I don't see how a current such as 1 milliamp is going to increase it that much, you know?
If the current doubles, the torque should at least double, but you're saying the external magnetic field would have to double too (since B is the external magnetic field). How does that work?
And if there was no external magnetic field, how would you define the torque on the magnetic field of the loop anyway?
By the way, the opening post was asking about whether the magnetic field corresponded to the resistive voltage drop or the time-integrated inductive voltage drop, and I think the answers suggested the latter (1/2)LI^2. Now I trying to figure how exactly does the external magnetic field, which is really [itex]\mathbf{B}_{ext}[/itex], is proportional to the current it couples to.
FAQ: Effects of various voltage drops in passive circuits
What is a passive circuit?
A passive circuit is an electrical circuit that does not require an external power source to function. It may contain resistors, capacitors, and inductors, but does not include active components such as transistors or amplifiers.
What is voltage drop in a passive circuit?
Voltage drop in a passive circuit refers to the decrease in voltage that occurs as the current passes through the circuit components. This is due to the resistance of the components, which causes some of the electrical energy to be converted into heat.
What are the effects of voltage drops in a passive circuit?
The effects of voltage drops in a passive circuit include a decrease in the overall voltage of the circuit, a decrease in the amount of current flowing through the circuit, and an increase in the heat dissipated by the components. This can also lead to a decrease in the performance of the circuit and potential damage to the components.
How does the amount of voltage drop affect a passive circuit?
The amount of voltage drop in a passive circuit is directly related to the resistance of the components and the amount of current flowing through the circuit. As the voltage drop increases, the overall voltage of the circuit decreases and the amount of current decreases as well. This can affect the functionality and performance of the circuit.
What factors can cause voltage drops in a passive circuit?
Voltage drops in a passive circuit can be caused by various factors such as the material and size of the circuit components, the length and thickness of the wires, and the temperature of the circuit. Other external factors such as interference and environmental conditions can also contribute to voltage drops in a passive circuit.
