Efficiency model in loophole free photon Bell tests
In summary, the assumed photon detection efficiency model used in experiments testing Bell inequalities is a crucial factor in accurately interpreting results and must be carefully validated and reported to avoid potential errors and underestimation of sample size.
zonde
224
I would like ask comments about assumed photon detection efficiency model used in these experiments that test Bell inequalities and consequences if it does not hold.
http://arxiv.org/abs/1511.03189
http://arxiv.org/abs/1511.03190
Detection efficiency is calculated as two-fold coincidence events divided by singles counts (from one side). That method assumes equal nondetection probability for all photons. But if we have different nondetection probabilities some error estimates would come out different.
I made a simple mathematical test. I compare single sample with identical detection probabilities for all photons and another sample that consists of two subsamples where one has 100% detection probability and the other one has 25% detection probability.
Code:
True sample size    single detections    coincidences    detection efficiency
Sample 1
160                        120               90              90/120=75%
Sample 2
80                         80                80              80/80=100%
160                        40                10              10/40=25%
Notice that average efficiency for sample 2 would come out the same as for sample 1 as single counts and coincidences sum up to the same numbers as in sample 1.
From this example it seems that if detection efficiency model does not hold we can underestimate true sample size and that can spoil some error calculations e.g. double photon rate.
Thank you for bringing up this important issue. The assumed photon detection efficiency model used in experiments testing Bell inequalities is a crucial factor in accurately interpreting the results. As you have demonstrated in your mathematical test, if the model does not hold, it can lead to underestimation of the true sample size and potentially affect error calculations.
It is important for researchers to thoroughly validate and calibrate their detection efficiency models to ensure accurate results. This can be done through careful experimental design and analysis, as well as using control samples with known detection probabilities.
In addition, it is crucial to clearly report and discuss the assumptions and limitations of the detection efficiency model used in the experiment. This will allow for a better understanding of the potential impact on the results and any necessary adjustments or corrections that may need to be made.
Overall, it is important for scientists to be aware of and carefully consider the assumptions and limitations of any models used in experiments, and to continuously strive for accurate and reliable results. Thank you for bringing attention to this issue and for your contribution to the scientific community.
Related to Efficiency model in loophole free photon Bell tests
What is an efficiency model in loophole free photon Bell tests?
An efficiency model in loophole free photon Bell tests is a mathematical framework used to describe the efficiency of the detectors used in quantum experiments. It takes into account factors such as detector efficiency, dark counts, and background noise to ensure that the results of the experiment are not affected by any loopholes.
Why is an efficiency model important in loophole free photon Bell tests?
An efficiency model is important because it allows scientists to accurately interpret the results of quantum experiments and rule out any possible loopholes. Without an efficiency model, the results of the experiment may be skewed or biased, leading to incorrect conclusions.
How is an efficiency model calculated in loophole free photon Bell tests?
An efficiency model is typically calculated using statistical methods and data from previous experiments. It takes into account factors such as photon detection rates, background noise, and detector efficiency to determine the overall efficiency of the detectors used in the experiment.
What are the limitations of an efficiency model in loophole free photon Bell tests?
One limitation of an efficiency model is that it relies on assumptions and simplifications, which may not accurately reflect the real-world conditions of the experiment. Additionally, an efficiency model may not account for all possible sources of error, leading to potential loopholes in the results.
Can an efficiency model be improved or refined in loophole free photon Bell tests?
Yes, an efficiency model can be refined and improved as new data and technologies become available. As scientists gain a better understanding of the factors that affect detector efficiency, the efficiency model can be updated to provide more accurate and reliable results in loophole free photon Bell tests.
  • Quantum Physics
  • Quantum Physics
10K
  • Quantum Physics
  • Quantum Physics
