Efficient Fast Orbital Transportation/Construction?
  • B
  • Thread starter IsItSo
  • Tags
    Orbital
In summary, Centaur argues that the flywheel system would require a lot of energy to keep the flywheels spinning, and if the projectiles are not released at the same time, the far flywheel would be destroyed.
IsItSo
32
Is it plausible that you could launch a flywheel into a geostationary orbit, have it spinning very fast, and from both sides release two parcels at the same time so the flywheel doesn't go off course and so the 2 parcels travel in orbit to the other side of the Earth and re-attach to another awaiting flywheel? If this is correct this would allow for minimal energy loss and fast travel/construction.
How do you keep the flywheels spinning?
Because they're in space?...Won't they basically indefinitely keep spinning?
If they are to be used for projecting a payload into a higher orbit then they will, in principle, need just as much energy put in as if you use a burst of rocket fuel.
I'm confused, is the whole idea plausible?
No. The energy put into the projectiles subtracts from the rotational energy of the flywheel. There is no "free energy".
Not as you stated it, it's not practical. The projectiles still need maneuvering fuel to accurately reach their target, so you don't save much by having to keep using fuel to spin the flywheels back up.
I'm confused too because you haven't actually described what it would do. In principle, you could use two long arms to give two loads a lot of kinetic energy by gradually building up the speed with a low power unit and then releasing them at just the right time in the rotation cycle. What would be done on the other side - remember that the two loads would have a higher orbit from the original launch system.
What is your system supposed to achieve? Is it a kind of postal system?
Good point, I missed that subtlety. :smile:
It's supposed to achieve a whole bunch of flywheels (and technological-structure) staying in space - in a geo-stationary orbit, with the flywheels holding the stored energy for a long time, and so, when the constructors want to transport matter, they can *quickly and *efficiently transport matter to even the other side of Earth say, and capture back the energy in the awaiting flywheel so minimal energy is lost.
Could it work?
Could it work?
In a word, No.
Did you understand Centaur's point about what happens to your orbital height as a function of the added energy? Do you have any idea how much fuel it would take to try to maneuver to have both projectiles hit the far flywheel at exactly the same time? If you were off by so much as a second trying to dock, it could destroy both projectiles and the far flywheel.
So you're saying the far flywheel on the other side of Earth, when hit by the precisely timed parcels, will go into higher orbit??
I don't get it, you have two flywheels on opposite sides of Earth, with the same orbital height all perfectly, and one flywheel is spinning fast with two loads, then releases them and they re-attach to the other flywheel. I'm really anticipating what could be wrong :) !
When the projectiles leave the first flywheel with a higher velocity than they had when attached to the first flywheel, they will rise to the higher orbit that corresponds to that higher velocity. They miss the far flywheel as they fly right over it, unless you burn maneuvering fuel to lower their velocity and aim for the far flywheel. But if they have the lower velocity to match the far flywheel's orbital height...
And you still are not understanding how hard it is to super-precisely match two projectiles over many thousands of kilometers of flight.
Maybe it's time to put down the comic books and pick up the physics textbooks? :smile:
I understand the precision. I'm putting the precision on the shoulders of a future super-artificial-intelligence.
So as you said at the end, if their velocities when let go were not so big then they would not go diagonal and rather be on the same height level and would work?
It would be more efficient to just use fuel to give the extra transfer velocity to any inter-satellite transfers.
Thread closed temporarily for Moderation (and out of scientific frustration...)
After a Mentor discussion, @IsItSo -- if you can PM me your quantitative analysis of this proposal, we can re-open your thread. Until that time, it will remain closed.
Related to Efficient Fast Orbital Transportation/Construction?
1. How can we make orbital transportation more efficient and faster?
There are several ways to improve the efficiency and speed of orbital transportation. One method is by using advanced propulsion systems, such as ion engines, which can provide continuous acceleration and reach higher speeds compared to traditional chemical rockets. Another approach is to use reusable launch vehicles, which can significantly reduce the cost and time required for each launch. Additionally, optimizing the trajectory and launch windows can also contribute to faster and more efficient orbital transportation.
2. What are the challenges of constructing structures in space?
Constructing structures in space presents several challenges, including the lack of gravity and atmospheric pressure, extreme temperatures, and exposure to radiation. These factors require specialized materials and construction techniques to ensure the durability and safety of the structures. Another challenge is the high cost and logistical difficulties of transporting materials and equipment to space.
3. How can we minimize the environmental impact of orbital construction?
To minimize the environmental impact of orbital construction, it is crucial to use sustainable materials and methods. This includes using recyclable materials and reducing waste production. Additionally, implementing strict regulations and guidelines for orbital construction can help mitigate the potential negative effects on the environment and space debris.
4. What role does automation play in efficient orbital transportation and construction?
Automation plays a crucial role in efficient orbital transportation and construction. It can help reduce human error and increase the speed and accuracy of tasks. For example, automated systems can assist in spacecraft maneuvering and docking, as well as in the construction and maintenance of structures in space. This can ultimately lead to more cost-effective and time-efficient operations.
5. What are the potential benefits of efficient and fast orbital transportation and construction?
The benefits of efficient and fast orbital transportation and construction are numerous. It can significantly reduce the cost and time required for space missions, making space exploration and research more accessible. It can also lead to the development of new technologies and industries, creating economic opportunities. Additionally, efficient and fast orbital transportation and construction can aid in the establishment of permanent human settlements in space, expanding our understanding and capabilities in the universe.
  • Other Physics Topics
  • Aerospace Engineering
  • Astronomy and Astrophysics
