MHB Effie's question via email about a volume by revolution
The volume of the solid formed by rotating the region between the functions y = 2x² and y = x + 1 around the line y = 3 is calculated using integration. The points of intersection are found at x = 1 and x = -1/2, leading to the setup of two integrals: one for the outer volume and one for the inner volume. The outer volume is given by the integral of π(2x² - 3)² from -1/2 to 1, while the inner volume is π(x - 2)² over the same interval. After evaluating both integrals, the total volume is determined to be 99π/20 cubic units. Additionally, when rotating the same region around the line x = -1, the volume is found to be 105π/16 cubic units.
Prove It
MHB
What is the volume of the solid formed by the region bounded between the functions $\displaystyle \begin{align*} y 2\,x^2 \end{align*}$ and $\displaystyle \begin{align*} y = x + 1 \end{align*}$ being rotated around the line $\displaystyle \begin{align*} y = 3 \end{align*}$?
To start with, we should find the points of intersection of the two functions, as these will be the terminals of our regions of integration.
$\displaystyle \begin{align*} 2\,x^2 &= x + 1 \\ 2\,x^2 - x - 1 &= 0 \\ 2\,x^2 - 2\,x + x - 1 &= 0 \\ 2\,x\,\left( x - 1 \right) + 1 \,\left( x - 1 \right) &= 0 \\ \left( x - 1 \right) \left( 2\,x + 1 \right) &= 0 \\ x - 1 &= 0 \textrm{ or } 2\,x + 1 = 0 \\ x &= 1 \textrm{ or } x = -\frac{1}{2} \end{align*}$
As we are rotating around the line $\displaystyle \begin{align*} y = 3 \end{align*}$, it would make sense to move everything down by 3 units. The areas and volumes will still be exactly the same, but we will be rotating around the x axis.
The furthest function from the x-axis will be $\displaystyle \begin{align*} y = 2\,x^2 - 3 \end{align*}$, so we should evaluate the volume formed by rotating the area between that function and the x-axis between $\displaystyle \begin{align*} x = -\frac{1}{2} \end{align*}$ and x = 1 around the x axis, and then subtract the volume formed by rotating the area between the function $\displaystyle \begin{align*} y = x - 2 \end{align*}$ and the x-axis between $\displaystyle \begin{align*} x = -\frac{1}{2} \end{align*}$ and x = 1 around the x axis.
To evaluate each volume, picture each region being broken up into a number of rectangles. Each rectangle will then be rotated around the x-axis to form a cylinder. The volume of a cylinder is $\displaystyle \begin{align*} \pi\,r^2\,h \end{align*}$. Each cylinder will have a radius that is the same as the y value, and a height that is equal to $\displaystyle \begin{align*} \Delta x \end{align*}$, a small change in x.
So the outer volume we can approximate by $\displaystyle \begin{align*} \sum{ \pi\,\left( 2\,x^2 - 3 \right) ^2 \,\Delta x } \end{align*}$, and if we increase the number of cylinders (making each cylinder thinner) we get a better approximation. As $\displaystyle \begin{align*} n \to \infty \end{align*}$ and $\displaystyle \begin{align*} \Delta x \to 0 \end{align*}$, the approximation becomes exact and the sum becomes an integral. So the outer volume is exactly $\displaystyle \begin{align*} \int_{-\frac{1}{2}}^1{ \pi\,\left( 2\,x^2 - 3 \right) ^2\,\mathrm{d}x } \end{align*}$. By identical arguments, the inner volume to be subtracted is exactly equal to $\displaystyle \begin{align*} \int_{-\frac{1}{2}}^1{ \pi\,\left( x - 2\right) ^2 \,\mathrm{d}x } \end{align*}$. Thus the total volume we want to evaluate is
$\displaystyle \begin{align*} v &= \int_{-\frac{1}{2}}^1{ \pi\,\left( 2\,x^2 - 3 \right) ^2\,\mathrm{d}x } - \int_{-\frac{1}{2}}^1{ \pi\,\left( x - 2 \right) ^2\,\mathrm{d}x } \\ &= \pi\int_{-\frac{1}{2}}^1{ \left[ \left( 2\,x^2 - 3 \right) ^2 - \left( x - 2 \right) ^2 \right] \,\mathrm{d}x } \\ &= \pi \int_{-\frac{1}{2}}^1{ \left[ 4\,x^4 - 12\,x^2 + 9 - \left( x^2 - 4\,x + 4 \right) \right] \,\mathrm{d}x } \\ &= \pi\int_{-\frac{1}{2}}^1{ \left( 4\,x^4 - 13\,x^2 + 4\,x + 5 \right) \,\mathrm{d}x } \\ &= \pi\,\left[ \frac{4\,x^5}{5} - \frac{13\,x^3}{3} + 2\,x^2 + 5\,x \right] _{-\frac{1}{2}}^1 \\ &= \pi\,\left\{ \left[ \frac{4\,\left( 1 \right) ^5}{5} - \frac{13\,\left( 1 \right) ^3}{3} + 2\,\left( 1 \right) ^2 + 5\,\left( 1 \right) \right] - \left[ \frac{4\,\left( -\frac{1}{2} \right) ^5}{5} - \frac{13\,\left( -\frac{1}{2} \right) ^3}{3} + 2\,\left( -\frac{1}{2} \right) ^2 + 5\,\left( -\frac{1}{2} \right) \right] \right\} \\ &= \pi \,\left\{ \left( \frac{4}{5} - \frac{13}{3} + 2 + 5 \right) - \left[ \frac{4\,\left( -\frac{1}{32} \right)}{5} - \frac{13\,\left( -\frac{1}{8} \right) }{3} + 2\,\left( \frac{1}{4} \right) - \frac{5}{2} \right] \right\} \\ &= \pi\,\left[ \left( \frac{12}{15} - \frac{65}{15} + \frac{105}{15} \right) - \left( -\frac{1}{40} + \frac{13}{24} + \frac{1}{2} - \frac{5}{2} \right) \right] \\ &= \pi\,\left[ \frac{52}{15} - \left( -\frac{3}{120} + \frac{65}{120} - \frac{240}{120} \right) \right] \\ &= \pi\,\left[ \frac{52}{15} - \left( -\frac{178}{120} \right) \right] \\ &= \pi\,\left( \frac{52}{15} + \frac{89}{60} \right) \\ &= \pi\,\left( \frac{208}{60} + \frac{89}{60} \right) \\ &= \pi\,\left( \frac{297}{60} \right) \\ &= \frac{99\,\pi}{20}\,\textrm{units}^3 \end{align*}$
Mathematics news on Phys.org
Using the same region, what will be the volume of the solid if that region is rotated around the line $\displaystyle \begin{align*} x = -1 \end{align*}$?
To do this, picture what it would look like if the region was rotated about the vertical line x = -1. This solid can be thought of as a bunch of vertically oriented thin hollow cylinders being stuck together. If we move everything right by 1 unit, the volumes will be the same, but we will rotate around the y axis. So we really want the area between $\displaystyle \begin{align*} y = x \end{align*}$ and $\displaystyle \begin{align*} y = 2\,\left( x - 1 \right) ^2 \end{align*}$ with $\displaystyle \begin{align*} \frac{1}{2} \leq x \leq 2 \end{align*}$.
The curved surface of each cylinder is a rectangle. The width of the rectangle is equal to the vertical distance between the two functions, so $\displaystyle \begin{align*} y_2 - y_1 = x - 2\,\left( x - 1 \right)^2 = x - 2\,\left( x^2 - 2\,x + 1 \right) = x - 2\,x^2 + 4\,x - 1 = 5\,x - 2\,x^2 - 1 \end{align*}$, and the length is the same as the circumference of the cylinder, so $\displaystyle \begin{align*} 2\,\pi\,r \end{align*}$. Since the radius of each cylinder is the x value of the function, that means the area of the curved surface of each cylinder is $\displaystyle \begin{align*} 2\,\pi\,x\,\left( 5\,x - 2\,x^2 - 1 \right) \end{align*}$, and thus the volume of each cylinder is $\displaystyle \begin{align*} 2\,\pi\,x\,\left( 5\,x - 2\,x^2 - 1 \right) \,\Delta x \end{align*}$, where $\displaystyle \begin{align*} \Delta x \end{align*}$ is a small change in x.
We can therefore approximate the total volume by adding up the volumes of all these cylinders, so $\displaystyle \begin{align*} \sum{ 2\,\pi\,x\,\left( 5\,x - 2\,x^2 - 1 \right) \,\Delta x } \end{align*}$. As we increase the number of cylinders, thereby making each one thinner, the approximation gets better. So as $\displaystyle \begin{align*} n \to \infty \end{align*}$ and $\displaystyle \begin{align*} \Delta x \to 0 \end{align*}$, the approximation becomes exact, and the sum becomes an integral. So the volume of the solid is exactly
$\displaystyle \begin{align*} V &= \int_{\frac{1}{2}}^2{ 2\,\pi\,x\,\left( 5\,x - 2\,x^2 - 1 \right) \,\mathrm{d}x } \\ &= 2\,\pi\int_{\frac{1}{2}}^2{ \left( 5\,x^2 - 2\,x^3 - x \right) \,\mathrm{d}x } \\ &= 2\,\pi \,\left[ \frac{5\,x^3}{3} - \frac{x^4}{2} - \frac{x^2}{2} \right] _{\frac{1}{2}}^2 \\ &= 2\,\pi\,\left\{ \left[ \frac{5\,\left( 2 \right) ^3}{3} - \frac{2^4}{2} - \frac{2^2}{2} \right] - \left[ \frac{5\,\left( \frac{1}{2} \right) ^3}{3} - \frac{\left( \frac{1}{2} \right) ^4}{2} - \frac{\left( \frac{1}{2} \right) ^2}{2} \right] \right\} \\ &= 2\,\pi\, \left[ \left( \frac{40}{3} - 8 - 2 \right) - \left( \frac{5}{24} - \frac{1}{32} - \frac{1}{8} \right) \right] \\ &= 2\,\pi \,\left[ \left( \frac{40}{3} - \frac{30}{3} \right) - \left( \frac{20}{96} - \frac{3}{96} - \frac{12}{96} \right) \right] \\ &= 2\,\pi \, \left( \frac{10}{3} - \frac{5}{96} \right) \\ &= 2\,\pi\,\left( \frac{320}{96} - \frac{5}{96} \right) \\ &= 2\,\pi\,\left( \frac{315}{96} \right) \\ &= 2\,\pi\,\left( \frac{105}{32} \right) \\ &= \frac{105\,\pi}{16}\,\textrm{units}^3 \end{align*}$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
