Effusing gas onto the interior of an evacuated sphere
In summary, the conversation discusses the gas effusion into a vacuum through a small hole and the possibility of a uniform coating if the particles effuse into an evacuated sphere and condense where they collide. The conversation also mentions relevant equations, such as the angular probability distribution and surface area of a ring defined on a sphere. It is noted that there are some issues with the 2π sin(θ)dθ formula, including the lack of a constant hypotenuse length and consideration of the varying angle between the beam and surface.
Toby_phys
A gas effuses into a vacuum though a small hole of area [tex]A[/tex]. Show that if the particles effused into an evacuated sphere and the particles condensed where they collided that there would be a uniform coating. (7.6 of Blundell and Blundell)
Angular probability distribution. The probability a particle is traveling between [tex]\theta[/tex] and [tex]\theta+d\theta[/tex] to the normal of the small hole.
cos\theta sin\theta d\theta
Surface area of a ring defined on the surface of a sphere with radius of unity where the angles go from [tex]\theta[/tex] to [tex]\theta+d\theta[/tex]
2\pi sin\theta d\theta
Surely it would just be amount of particles over area which is proportional to [tex]cos\theta[/tex]. This is clearly not uniform
There are a few things wrong with your 2π sin(θ)dθ formula.
First, you have no hypotenuse length in there, and it will not be constant.
Second, you are not considering the oblique and varying angle between the beam and the surface.
Third, different dθ wedges will contain different fractions of the beam.
Related to Effusing gas onto the interior of an evacuated sphere
1. What is effusing gas onto the interior of an evacuated sphere?
Effusing gas onto the interior of an evacuated sphere is a process in which gas molecules are introduced into a previously empty sphere. This can be done using a gas source connected to the sphere and allowing the gas to flow in.
2. What is the purpose of effusing gas onto the interior of an evacuated sphere?
The purpose of this process is to study the behavior of gas molecules in a confined space. By controlling the gas flow and measuring the pressure, scientists can gain insights into gas dynamics and properties such as diffusion and thermal conductivity.
3. How is effusing gas onto the interior of an evacuated sphere different from simply filling a sphere with gas?
Effusing gas onto the interior of an evacuated sphere involves a controlled introduction of gas molecules into a previously empty space. This allows for precise measurement and study of gas behavior. On the other hand, simply filling a sphere with gas may result in a mixture of different gas molecules and make it difficult to control and measure specific properties.
4. What are some applications of effusing gas onto the interior of an evacuated sphere?
This process is commonly used in scientific research and experiments, particularly in the fields of gas dynamics and material science. It can also be used in the production of vacuum-sealed products or in the development of specialized gas sensors.
5. Are there any safety precautions to consider when effusing gas onto the interior of an evacuated sphere?
Yes, it is important to handle and store gas sources properly to avoid potential hazards. It is also crucial to carefully monitor the pressure and gas flow during the process to prevent over-pressurization of the sphere. Proper ventilation and use of personal protective equipment may also be necessary.
