Egg drop project landing module
In summary, for an 8th grade honors science class project, students have been assigned to create a landing module that can fit in a 10cm x 10cm x 10cm box and hold a large sized egg. The module must also be able to withstand a 3 meter drop onto a concrete floor, land upright, and have handles for carrying. Design ideas include a pyramid shape and using small parachutes. The main challenge is to prevent the egg from cracking due to the force of the impact. Students are allowed to use any materials except for glass, liquid padding, and food. Experimentation is encouraged to test and improve designs.
Firestorm
For my 8th grade honors science class we are currently doing astronomy. We got assigned a project where we have to create a landing module like the module that people land back on Earth in. The catch is that it has to be able to fit in a 10cm x10cm x10cm box and be able to fit a large sized egg so the hatch has to be approx. 5.8cm x4.3cm. The drop height will be about 3 meters and has to land upright on the concrete floor so that the hatch can be reopened to remove the egg to check for cracks and whatnot. It also has to have like handles or something so that it can be held. The module itself can't have any glass, liquid padding, or any food like peanut butter. We are also able to use small parachutes.
I was thinking of like a Pyramid type module so that when it is released at approx. the air will be pushing back on the large bottom when dropped making a natural airbrake. What is your guys' opinion?
Welcome to PF;
I think you should build a pyramid and drop it and watch how it falls and you will answer your question.
When you think of a design, try to build it so it can be tested - then test it out. Do pyramids generally fall bottom first for example? What's wrong with just building a 10cm cube?
Doing the experiment is a big part of science, and this assignment - so go do it and see.
Your main issue is not so much that the container should remain intact, but that the egg should remain intact.
The rest is window dressing. What is it about the fall that breaks the egg?
The force of the impact is what breaks the egg. ^^
Kinda - what is it about the force of the impact that makes it hard enough to break the egg?
Have you had a go dropping some pyramids yet?
What are the allowed materials and what not? In doing this a while ago, I found it often was best to make a simple design, as anything else often resulted in complications. Such as one simply consisting of a harder layer, then cushioning (as much as possible, followed by the egg, and using something to hold it in place . Also, it seems paramount in this assignment that it lands bottom down, keep that in mind during your design.And (out of curiosity) how exactly are the parachutes allowed? Do they have the same requirements, or any size requirements? Using them can lower the speed, but if made imperfectly can cause problems.
And if possible, you should try and test your designs when able, since I have found, that depending on what your given, results can vary immensely.
And with a pyramid design, try simply dropping some roughly pyramid shaped object (like a common 4 sided die if you have one) from different heights to get a good feel of how it may fall, and just because you have a large surface (such as the bottom of a pyramid), does not necessarily mean it will be slower, try testing your design against the basic box restriction, or a sphere, to make certain it is an improvement.
The parachute will be draped over the box, but on release the chute won't be held any certain way. Our teacher has us doing the project in phases and the first phase is a sketch of our landing module. We can use any materials we want, but no glass, liquid padding or food like peanut butter.
The module hitting the ground would cause shockwaves to go through the craft which may reach the egg causing damage I believe.
FAQ: Egg drop project landing module
What is an egg drop project landing module?
An egg drop project landing module is a protective device used in science experiments designed to test the impact of a fall on an egg. It is typically made from materials such as cardboard, straws, and cushioning materials to prevent the egg from breaking upon impact.
What is the purpose of an egg drop project landing module?
The purpose of an egg drop project landing module is to protect an egg from breaking when dropped from a certain height. This allows students to explore concepts such as gravity, acceleration, and impact forces through a hands-on experiment.
How does an egg drop project landing module work?
The landing module works by absorbing the impact of the fall through its design and materials. The materials used, such as straws or cushioning, are meant to slow down the egg's descent and distribute the impact force over a larger area, reducing the chances of the egg breaking.
What materials can be used to make an egg drop project landing module?
Commonly used materials for an egg drop project landing module include cardboard, straws, bubble wrap, cotton balls, and foam. Students can also get creative and use materials such as rubber bands, popsicle sticks, and paper cups to build their landing module.
What factors should be considered when designing an egg drop project landing module?
There are several factors to consider when designing an egg drop project landing module, including the weight and size of the egg, the height from which it will be dropped, and the materials used. The design should also include shock-absorbing features and a way to secure the egg in place to prevent it from bouncing or rolling out during the fall.
